Do I want/need a 72 or 84" box blade?
   / Do I want/need a 72 or 84" box blade? #21
I'm looking for a 8'6" angled front blade to cover my tracks when plowing snow with 4720. I currently use a 84" front blade that works fine but does not cover my tracks. Does anyone know where I can find one?
JPC
   / Do I want/need a 72 or 84" box blade? #22
I can see that being beneficial for most operators. When I'm cutting next to a building, I cut with the BB as close as I'm comfortable with then switch to sweep cuts with the bucket at a slight angle.
I do the unthinkable (at least to many on here). I cut almost all of my swales with the BB backing up...THE HORROR!!! I also rip them first with the scarifiers and then cut them in 2WD. Even with loaded rears and a 1000+ BB making small cuts at a time, it'll spin before anything breaks. Of course, in rocky ground its a recipe for disaster, so I cut them heading forward.
I don't work next to buildings very often so I prefer the 84" width box blade. I use reverse while grading too in clean ground after loosening it up, seems to work easier with less corrections needed to hold a grade. I don't get in a big hurry though.
   / Do I want/need a 72 or 84" box blade? #23
It seems like every rural property I work at has a metal shop or barn.
I used to grade quite a bit in reverse in 4wd, until I spun a splined driveline coupler on my front pinion. The soft splines on the $30 coupler removed the hardened splines on the $2000 pinion. Go figure.
2018 Bandit 15XP Wood Chipper (A57453)
2018 Bandit 15XP...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
Giyi Pallet Forks (A53314)
Giyi Pallet Forks...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55302)
2016 RAM 5500...
1999 FREIGHTLINER FLATBED (A58214)
1999 FREIGHTLINER...
2016 Cadillac CTS Sedan (A56859)
2016 Cadillac CTS...
