Do I want/need a 72 or 84" box blade?
   / Do I want/need a 72 or 84" box blade? #21
I'm looking for a 8'6" angled front blade to cover my tracks when plowing snow with 4720. I currently use a 84" front blade that works fine but does not cover my tracks. Does anyone know where I can find one?
JPC
   / Do I want/need a 72 or 84" box blade? #22
I can see that being beneficial for most operators. When I'm cutting next to a building, I cut with the BB as close as I'm comfortable with then switch to sweep cuts with the bucket at a slight angle.
I do the unthinkable (at least to many on here). I cut almost all of my swales with the BB backing up...THE HORROR!!! I also rip them first with the scarifiers and then cut them in 2WD. Even with loaded rears and a 1000+ BB making small cuts at a time, it'll spin before anything breaks. Of course, in rocky ground its a recipe for disaster, so I cut them heading forward.
I don't work next to buildings very often so I prefer the 84" width box blade. I use reverse while grading too in clean ground after loosening it up, seems to work easier with less corrections needed to hold a grade. I don't get in a big hurry though.
   / Do I want/need a 72 or 84" box blade? #23
It seems like every rural property I work at has a metal shop or barn.
I used to grade quite a bit in reverse in 4wd, until I spun a splined driveline coupler on my front pinion. The soft splines on the $30 coupler removed the hardened splines on the $2000 pinion. Go figure.
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2008 JOHN DEERE 310SJ BACKHOE (A52709)
2008 JOHN DEERE...
2013 John Deere 245G LC (A55272)
2013 John Deere...
New/Unused 200lbs Cast Iron Anvil (A57454)
New/Unused 200lbs...
Meyer 8.5' Snow Plow (A55272)
Meyer 8.5' Snow...
Hays LT1 Tender (A56438)
Hays LT1 Tender...
