Do You Block The Trailer Rear End Before Loading?
   / Do You Block The Trailer Rear End Before Loading? #21
I always blocked the back of my trailer when I was towing behind my old SUV, which was fairly light. Carried a couple chunks of 6x6 around for that and general rigging work. With my truck, which is a heck of a lot heavier, it's not so much of an issue and I don't block. But I would do it it if loading a heavier tractor. With a long trailer, it doesn't take a whole lot of dip in the rear to raise the tongue up. Probably about a 2:1 or 3:1 seesaw there.
And don't forget the parking brake of most all vehicles is on the back end. I remember reading a story here about someone who lifted the back end of their truck off the ground when driving a tractor onto their trailer, which in turn caused the truck and trailer to start rolling forward. Bet that was a eye opener! Good reminder to chock the trailer tires.
   / Do You Block The Trailer Rear End Before Loading? #22
All I can say is that if your PU rear end is in the air you are doing something wrong.
OK, if the loading area is perfectly flat you'll get away with it.
So simple to add a few blocks under the trailer rear and avoid troubles.
In a perfect world you would have 2 tongue jacks at each rear corner or some other device to to prop that trailer while loading.
   / Do You Block The Trailer Rear End Before Loading? #23
on my old trailer i added 2 swivel jacks to rear of trailer. beats the heck out of blocks. made a big difference. My new trailer is a tilt bed, so no longer any issues. TRAILER BRACKET 4.jpg TRAILER BRACKET 3.jpg TRAILER BRACKET 2.jpg TRAILER BRACKET 1 copy.jpg
   / Do You Block The Trailer Rear End Before Loading? #24
Am I being a girly man about this? :)
Pretty sure that's just being smart! It may not be necessary for lighter loads, but it's sure not going to hurt anything. The big thing I see is people forgetting to set the parking brake on automatics when they load their trailers. That can put quite a load on a pretty small piece of metal in an automatic transmission.
   / Do You Block The Trailer Rear End Before Loading? #25
One other thing I have learned messing with boats for the last 30 years is if you have 4x4 use it! By doing so when you shift into Park (P) it now locks up not only the rear axle but the front also.
I bet I have seen 15 4x4 trucks and SUV's end up in the drink launching, not retrieving, boats. When I ask why did you use the 4x4 they all say the same thing, "don't need it to put the boat in".
Chris
   / Do You Block The Trailer Rear End Before Loading? #26
I put the truck in four wheel low. Put on the parking brake. And I have a toggle switch to power the trailer brakes independent of the controller. Don't usually put a block under the back since it usually gets stuck and I don't like driving the trailer off the block. Have a soft suspension.
   / Do You Block The Trailer Rear End Before Loading? #27
No I don't block the trailer.
Haven't had to do that since 2005.
Tilt beds work for me.
   / Do You Block The Trailer Rear End Before Loading? #28
This guy needs blocks---and a tow vehicle hitched to the trailer.
Bruce
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
2016 FORD TRANSIT 350 CARGO (A59575)
2016 FORD TRANSIT...
154 (A52708)
154 (A52708)
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
207274 (A52708)
207274 (A52708)
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2019 KENWORTH T680...
