DK35vince
Super Member
Another on a power reverser.I think this video gives an idea of some of the transmission types as far as forward/reversing.
power reverser tractor transmission - Bing video
Thanks, sounds like caterpillar dozer transmissions I used to run.
You ever got the turn signal lever in your truck while trying to change directions? I do all the time.
I'm pretty sure these are all the same in their application from the driver's position:
Power Reverser (JD), Power Shuttle, Hydraulic Shuttle, GlideShift (Kubota)
I love my Power Reverser; I have often wondered about how the learning curve would be with the newer hydro tractors, I understand they have come a long way. I think the biggest problem I would have would be if they are the same as operating a Skid Loader, i.e. the engine speed needs to be high to get the response, and if you get in a bind, you have to ease up on the pedal to get the torque in the machine. I have been used to getting more power from anything with a motor by giving more pedal (or a twist of the throttle) for far too many years to make the change; I have used a zero turn mower for years, and still have to remind myself on hills in heavy cutting to pull back on the handles!
I get al kinds of discombobulated when switching from my HST lawn tractor to my geared tractor then to my automatic pickup. Still waiting on my learning curve to flatten out....![]()
I solved part of the problem by having my garden tractor, compact tractor and tlb all having the same pedal configuration.
I spend a lot of time turned around looking at my box blade and making adjustments to it on the fly for tilt and depth, being able to control the travel with a hydro is very convenient. It allows me to adjust the box blade before proceeding further along the way. This goes on all day long while finish grading at high accuracy.
