Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #22
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #23
I built a adapter out of some 1/2 X 2 flat bar I had laying around. I don't use the top hook at all, not even sure where the hook is anymore. I'll get a pic in a bit.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #24
Thanks so much for all the helpful advice!
I ended up purchasing the Titan attachments triangle one with a hitch. Primarily because there was an open box on ebay for $70 shipped. My plan is to purchase either the Tri-ball with a hook or just get a hook or d-ring receiver at harbor freight.
My tractor is only rated at 1438lbs on the pto so I really dont need anything super heavy duty. Other than the trailer I will probably only be dragging small trees. I also purchase the titan quick attach forks for the front loader. Ideally I would have like to have a 3 point hitch that would have allowed me to use the forks in the rear but I was unable to find a model like this other than a homemade version as shown below which is super cool and has a boom. I plan to make something similar in the future but I wanted to have something on hand when spring comes and we need to get the boat out.
I have the Titan receiver hitch with the pull ring, and I like it.
It is beautifully made, and powder coated.
You can buy a set of Titan 2000# 3pt. forks from Agri Supply for $180 + shipping.
They too, are quality built, and power coated.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #25
Re: Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments
Ok great thanks for the help. If you have some extra time could you post a picture of it connected to the quick hitch? I had planned on holding off on the quick hitch until the price drops to the sale price of $69.99. I do not really need it yet since my only two pto attachments are the triangle hitch and countyline carry all.
Had a little time today so worked on this.
For me the hook also is too far back. I hope to use the adaptor from HF work.
I added the class 1-2 and 2-3 bushings on the pins. And also top link bushings on the top link pink to fill the hook. I only have one bolt in it for the mocking up but I think even one good bolt or pin would be sufficient on my L3301. It would probably rear up or come to a dead stop or spin before breaking a 1/2"grade 8 bolt I would think. But the right way would be to scab on the back of the hook pushing it out. Maybe eventually.
My lower pins were a little too close together in their distance apart which caused the lunch pin to get hung up in the lower hooks. I added a couple of flat washers to push the pins out slightly.ImageUploadedByTapatalk1457126926.359939.jpg
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #26
Oh yeah I forgot. I wanted the carryall at first like you but I think a set of pallet forks like those from Agrisupply would be more useful. They can carry a pallet, flat plywood or a work box for you as a carryall in addition to doing pallet stuff. I use my dirt scoop because I want adjustable forks on the front to stump grub with someday.
   / Draw bar & Hitch Stabilizer vs Triangle hitch titan attachments #27
Do you remember what brand trailer mover you got, model number? Looking for one quick hitch compatable.
Do you want it quick hitch compatible?
I got one at Family Farm & Home for about $150. Probably a King Kutter brand.
Quick hitch compatible and it'll do goose neck trailers as well (not that I have one, but maybe one day.......).
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
HUSQVARNA RIDING...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
