Engine changes to Diesel x7xx series.
   / Engine changes to Diesel x7xx series.
2006 - 2010 = 49.1 ft pounds at 2,300 RPM
2011 - current = 40.9 ft pounds at 2,600 RPM
That would be the most concern for me
Kubota's diesel riding mower is only a 21HP machine and makes less torque then the new Yanmar diesel, so the new Yanmar must still be able to make some good power.
Not sure I like this line:
Rated output at 3600 rpm (intermittent): 23.6hp
in this spec sheet:
Diesel Progress Online | MINIMAX : Yanmar America Corp.
Couldn't find what engine speed is for pto speed on JD site? I think this engine in a Cub is 3300 @ PTO speed.
Could have something to do with Yanmar covering there behind. Engine manufacturers have gotten more and more sticky with there fine print. Ever since emissions laws became stricter, it's becoming increasingly difficult to get good performance out of an engine that has emissions controls on it.
   / Engine changes to Diesel x7xx series. #14
I was doing the same research not so long ago.
The change in engine and hydraulic drive took me by surprise, don't like to be the first to try new stuff. Even looked for a used 2010 X748 but did not find one in time. Dunno if you follow this
http://www.mytractorforum.com/showthread.php?t=156907
hope its ok to post links since it was done in another X700 thread.
The new motor should still be plenty as I think its used in the 1023E and the Yanmar 2400. The old 3TNV76 is in the 1026R?
The 2010 X748 was a little beast at 1.1 litres .. my BX2360 is only 0.9 so now they are equal
   / Engine changes to Diesel x7xx series. #15
Got to looking and forgot how small those tractors are. We got several damaged hoods off dealers for some of our builds. That new engine should be plenty for it.
   / Engine changes to Diesel x7xx series. #16
I look at it this way:
I've been lurking here to decide if I want to drop the long green (heh) on an X748 or X749. Despite the reduction in the size of the Yanmar motor I've got to believe that even the smaller unit will so far outlast the overheated, undercooled, oil-leaking mess of a Kohler in my Cub GT2544 that the four-fold price difference will be repaid in time and then some.
Either machine you go with you will be satisfied completely. You will save big money in fuel, maintenance, and lack of repairs needed. With the diesel X7xx series tractors, you can basically change the oil, and add diesel, and go on like that for years at a time.
I have never had any experience with Kohler engines, but I haven't heard the best things about them. I seen one torn down at a local lawn mower parts shop about 3 months back, and I was pretty unimpressed with it's condition for the low hours it had.
   / Engine changes to Diesel x7xx series. #18
I should also mention, and hopefully someone with more recall than I have can chime in, that new power equipment engines are being judged now by a stricter SAE standard, and all the power readings went down to better approximate the TRUE power of the engine in its said application. If the new Yanmar is being judged by this new stricter standard, it would seem that perhaps it is making more power than did the previous one in place. 23.6 HP, if under the new standard would be likely equivalent to 25-26 in the old standard. Also, I would have to express my reservation on the torque numbers on the X series small (24 HP diesels). I do not recall that they are rated with 49 lb/ft of torque. The 1 L Yanmar (also the same engine as my 2320 has) is rated at roughly 41 ft/lb torque. I have seen rated speed ranges from 39.6-41.7 ft. lb. on that engine but nothing up close to 50 (though I think it is possible the engine has that much). That higher number would put this engine really close in torque to the direct injected Yanmar in the 2520 with about 52. It looks like the new engine is making about 41 lb/ft, which would be right in the ballpark of the torque numbers I have seen from the previous engine. So assuming all this is true, that the HP/Tq are as good, or better with this engine and the engine has so many important upgrades, it likely would be a great choice. I would rely on someone with more up top than I have to verify or refute the numbers I had in my head.
John M
John M
To be honest, I am surprised they have not moved to direct injection with the diesels in the X7xx series. I thought for sure when this new engine came out for the 2011 model year it would have been direct injected.
Personally, I feel good about this new engine. I don't believe John Deere would continue to use Yanmar diesels in the X7xx series unless they could continue on with the reputation of that series. These machines are the top of line in there size and class, for John Deere to throw a unworthy engine under the hood would make no sense at all. Of course diehard fans would continue to buy no matter what even if they did use junk, but it would only be a matter of months before owners would rack up hours and tell the world of all there troubles.
The biggest choice I have now is between the X540 and the X748. Don't you hate that when your wallet decides things for you? At the same time, you only live once, so you feel like telling your wallet to shut up. :D
   / Engine changes to Diesel x7xx series. #20
I agree with you. There is a big price difference between those two machines. I think the engine JD puts in the Premium tractor will be fine. As you know JD is very particular about its engines and it will stand behind the product. I have never known Yanmar to make a bad engine. Over the years, I have had several of them in various pieces of JD equipment and have seen some incredible hour logs of machines powered by Yanmar. My perception is that this new engine is as powerful if not more powerful in reality than its predecessor. It likely is also cleaner running and more quiet. I bet it will also be better on fuel. If you can stomach the upfront cost of the 748, you will love the machine. If you go to sell it, unless it is in poor condition you should get a more significant portion of the original value out of the machine. My best analogy is the 455, a similarly sized machine that the X series replaced. When they come in on trade, my dealer, who is a large dealer, says they disappear at a rate of 3:1 v. the equivalent 445 gas powered machine.
John M
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
Set of Rubber Skidloader Tracks (A50774)
Set of Rubber...
1972 Baker 30ft Pole S/A Towable Trailer (A51694)
1972 Baker 30ft...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
6" Centrifugal Pump on Frame (A50121)
6" Centrifugal...
