jinman
Rest in Peace
- Joined
- Feb 23, 2001
- Messages
- 20,387
- Location
- Texas - Wise County - Sunset
- Tractor
- NHTC45D, NH LB75B, Ford Jubilee
WTA said:Can anyone think of ANYTHING else at all, no matter how stupid it may sound that can be causing my engine to miss badly, smoke white and die?
The problem is it's intermittent. Sometimes it will run fine at 2000 rpm here sitting in the driveway. The dealer said they ran it for two hours this time and it didn't act up. They replaced the lift pump and filter housing this time.
I'll bet you they had it sitting in the same place for the two hours they had it running. As you said, it sits in your driveway and runs fine. See your quote below.
WTA said:It ran 5 minutes after getting home before it died though. All I was doing was slowly driving across the field getting ready to mow and was at about 1500 rpm. I was using the foot throttle and at first the RPM started hunting mildly. I thought it was just my foot bouncing on the pedal so I switched over to the hand throttle and that's when it started blowing smoke and died.
Just looking for more ideas. Meanwhile I'm going shopping around for a new USED tractor. I have got to have something working here.
Have they ever replaced the fuel tank? If all your filters have air in them, it sure seems like a simple (yeah...sure!) fuel feed problem. As I remember, you first had this problem when you were using some red diesel and thought it might be some kind of clog. Am I right or do I have you confused with somebody else? If everything has been replaced except the tank, I think the tank would be next on my list even if it was a remote possibility.
BTW: I bet you the dealership went to more trouble painting the bolt and screw heads than they did driving your tractor. They need to hook up something and drive it up and down the road a couple of miles or around a rough field to get things sloshing around.
