Engine oil in my Hydaulics
   / Engine oil in my Hydaulics #1
steeevo
plymouth maine
2001 kubota bx1880
HELLO<, I have a 2003 kubota 1800 bx, deisel, I did a bonehead thing today, I put a qt of engine oil in my hydaulic tank. Will it be o.k if I just change the hydraulic fluid and filter, I did run it for 2-3 minutes after I added the engine oil,, (stupid).. I was told that motor oil won't hurt it. Is this true? ANYBODY??
   / Engine oil in my Hydaulics #2
Likely ok as is. But changing filter and fluid won’t hurt anything other than your wallet.
   / Engine oil in my Hydaulics #3
A quart is nothing in whatever many gallons the tractors holds. It won't hurt a thing.
   / Engine oil in my Hydaulics #4
I wouldn’t even change the fluid. A quart is pretty low dilution in the hydraulic system and motor oil wouldn’t hurt the hydraulics anyway.
   / Engine oil in my Hydaulics #5
I would not worry about it at all. Some machines use motor oil instead of hydraulic oil. Motor oil is a better grade of oil. Hydraulic oil is cheaper.
   / Engine oil in my Hydaulics #6
The OP’s machine is a Kubota BX1800 has both wet brakes and an HST. The recommended fluid is Kubota UDT or Super UDT. They are not a cheaper grade of oil.
   / Engine oil in my Hydaulics #7
It only costs more because Kubota oil doesn't foam. Which doesn't matter on a tractor. Now, a skid steer with a mulcher and high flow hydraulics is a different story. It needs a non foaming fluid.
   / Engine oil in my Hydaulics #8
There are many reason other than not foaming that requires high quality hydraulic fluid. HSTs and wet brakes are far more unforgiving than simple geared machines.
   / Engine oil in my Hydaulics #9
If I had a nickel for every Kubota I've worked on, I'd be rich.
   / Engine oil in my Hydaulics #10
In all my Kubota's I've never used UDT or SUDT and I've owner at least 10 and bought them all (except one) new. I do use their filters and OEM parts but the fluid is over rated and too expensive.
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55302)
2024 BCL...
12'x20' High End Carport (A53316)
12'x20' High End...
2006 Freightliner Business Class M2 Beverage Truck (A47477)
2006 Freightliner...
2015 Ford F-550 Stellar 7621 7,500LB 3 Ton Crane Service Truck (A55788)
2015 Ford F-550...
(4) CAMARO 5 LUG WHEELS & 245/50R16 97H TIRES (A54757)
(4) CAMARO 5 LUG...
