Engine oil in my Hydaulics
   / Engine oil in my Hydaulics #1
steeevo
plymouth maine
2001 kubota bx1880
HELLO<, I have a 2003 kubota 1800 bx, deisel, I did a bonehead thing today, I put a qt of engine oil in my hydaulic tank. Will it be o.k if I just change the hydraulic fluid and filter, I did run it for 2-3 minutes after I added the engine oil,, (stupid).. I was told that motor oil won't hurt it. Is this true? ANYBODY??
   / Engine oil in my Hydaulics #2
Likely ok as is. But changing filter and fluid won’t hurt anything other than your wallet.
   / Engine oil in my Hydaulics #3
A quart is nothing in whatever many gallons the tractors holds. It won't hurt a thing.
   / Engine oil in my Hydaulics #4
I wouldn’t even change the fluid. A quart is pretty low dilution in the hydraulic system and motor oil wouldn’t hurt the hydraulics anyway.
   / Engine oil in my Hydaulics #5
I would not worry about it at all. Some machines use motor oil instead of hydraulic oil. Motor oil is a better grade of oil. Hydraulic oil is cheaper.
   / Engine oil in my Hydaulics #6
The OP’s machine is a Kubota BX1800 has both wet brakes and an HST. The recommended fluid is Kubota UDT or Super UDT. They are not a cheaper grade of oil.
   / Engine oil in my Hydaulics #7
It only costs more because Kubota oil doesn't foam. Which doesn't matter on a tractor. Now, a skid steer with a mulcher and high flow hydraulics is a different story. It needs a non foaming fluid.
   / Engine oil in my Hydaulics #8
There are many reason other than not foaming that requires high quality hydraulic fluid. HSTs and wet brakes are far more unforgiving than simple geared machines.
   / Engine oil in my Hydaulics #9
If I had a nickel for every Kubota I've worked on, I'd be rich.
   / Engine oil in my Hydaulics #10
In all my Kubota's I've never used UDT or SUDT and I've owner at least 10 and bought them all (except one) new. I do use their filters and OEM parts but the fluid is over rated and too expensive.
2011 Kubota ZD326 (A53314)
2011 Kubota ZD326...
2006 International 4300 Altec TA50 50ft Material Handling Bucket Truck (A53422)
2006 International...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
TRASH TRAILER 16 T/A (A52472)
TRASH TRAILER 16...
Golf Cart (A55853)
Golf Cart (A55853)
2016 Jeep Compass 4X4 SUV (A55758)
2016 Jeep Compass...
