EPA issue ban on wood stoves
   / EPA issue ban on wood stoves #291
I have burned wood most of my life, and never really experienced inversions or excessive smoke from us or any of our neighbors. The last few years, I have noticed many outdoor boilers sooting BADLY. You could hardly see the road for several hundred feet. I wouldn't be opposed to regs on those nasty polluters, and keep the existing regs on stoves and fireplaces. Ours didn't smoke at all most of the time, just clear fumes rising out of the chimney. We usually burned 10 - 15 face cord of hardwood per season. the pellet stove we use right now smokes worse.
   / EPA issue ban on wood stoves #292
aR EPELLET STOVES MORE EFFICIENT?
   / EPA issue ban on wood stoves #293
That is kind of my point... my area has always had rules against excessive smoke and trash burning... same for any car the belches smoke too.
It's just now the burn bans apply to anyone burning... no matter if it is the old fireplace or the latest EPA clean certified wood stove... one size fits all!
   / EPA issue ban on wood stoves #295
I've been burning wood in a high efficiency wood stove for 20 years, and just replenished the wood stockpile, so, by no means am I for banning wood stoves. However, I just installed a ductless heat pump, and amazed how cheap it is to run, and the comfort level is amazing. The heat pump outside unit is an inverter style that speeds up and slows down according to heat/cooling load requirement of the house. The system does not cycle on/off like standard heating units.
Long story short, my wood burning days are coming to a close due to the super efficient new inverter heat pump technology. I live on the west coast with mild winters, and found the heat pump to work best when temps are no lower than 25 degrees f. Efficiency drops significantly at 20 and below.
   / EPA issue ban on wood stoves #296
I really don't know as we live in a different house as well. I do know I can walk outside on most any given day and if the wind is just right, the smoke will sting my eyes. This house will heat almost exclusively on 4 tons of pellets per year. It is, however a much better insulated house than our last which was log. (We were told by the kit seller of all the high R values and thermal mass bunk... NOT!) The pellets aren't burning as hot as the fireplace or stoves so I think there are more unburned gasses from the pellets.
   / EPA issue ban on wood stoves #297
I think you are naive if you don't think this is simply one of several steps to outright ban or regulate out of business any energy source that isn't politically correct, which of course would include wood burning, just as it has been with coal burning, fossil fuels, etc.
its not about fuels that are viewed as not PC, it's about the companies who make their living off fuels eliminating ANY form of competition or alternative fuel, no matter how small of a slice of the total energy picture it occupies.
When you have oil companies buying up patents for better chemistry batteries destined for use in electric cars and locking them away THAT'S what it's all about. Through their lobbyists in DC they are slowly either eliminating the competition or buying it up and making it their own.
   / EPA issue ban on wood stoves #298
Agreed, and add a group of irrational tree huggers who cannot grasp the concepts of "carbon neutral" or "renewable resource."
   / EPA issue ban on wood stoves #300
40006 (A53422)
40006 (A53422)
2011 Nissan Maxima Sedan (A53424)
2011 Nissan Maxima...
2001 JOHN DEERE 310G BACKHOE (A52705)
2001 JOHN DEERE...
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2018 Toro Workman GTX Electric Utility Cart (A51694)
2018 Toro Workman...
UNUSED LANDHONOR TP2-13-08D HYD TREE PULLER (A54757)
UNUSED LANDHONOR...
