schmism
Super Member
sandman2234 said:how expensive it is to replace it.
David from jax
didnt used to be!
David from jax
Not so expensive if you filter it and add it 10% to your diesel fuel. I would be pleased to take it if we were closer.pitt_md said:I changed my hydraulic oil last weekend on my MX5000. It has the mechanical shuttle tranny. The dealer said wait until 100 hours but I couldn't stand it when I hit 65 hours I had to change it. When I drained all 46.5 quarts from the 5 different drains it looked like it was new. $189.00 for oil and filter.![]()
SPYDERLK said:Not so expensive if you filter it and add it 10% to your diesel fuel. I would be pleased to take it if we were closer.
larry
Pour sand in it if you want, but you can get a lot more out of it without that additive as it fails slowly over the course of 20 or 30 yrs normal life.Soundguy said:Waste oil in my expensive injection pump? no thanks.. if I want to destroy the pump.. I can just pour sand in it and make it fail immediatly, and not wait for it to fail slowly later on...
soundguy
SPYDERLK said:Pour sand in it if you want, but you can get a lot more out of it without that additive as it fails slowly over the course of 20 or 30 yrs normal life.
larry
Actually, probably not. Probably because you dont put on a lot of hours. Not sure where youre sourcing the soot, and heavy metal of any appreciable size has already been filtered out or has settled in stagnant areas. We are talking low contaminant content and not of an abrasive nature.Soundguy said:If your injection pumps are only lasting 20-30 ys.. and you consider that normal life.. then I'd quit using the waste oil in them.
I mostly dink with antiques... I see plenty of diesels with non rebuilt pumps.. the pump on my 5000 is over 30ys old... looks to be doing fine too.. no over fueling.. starts easy.. cutoff works good.. etc. Probably because i don't contaminate it with heavy metals and soots.. you know.. things the injectors weren't made to handle... vs clean fuel... the stuff they were made to handle.
soundguy
It sure is odd that some people will notice when you change the subject, isnt it? I think Lincoln addressed that with a quote passed down thru the years.Soundguy said:Soot is abrasive. Heavy metals are present from engine component wear.. this can all be found in waste oil. just look at a used oil report.
I don't see any new vehicles or machines that instruct you to use your waste [crankcase oil] by adding it to your engine. ( And I'm not talking large marine vessle's either... )
soundguy
soundguy
SPYDERLK said:It sure is odd that some people will notice when you change the subject, isnt it? I think Lincoln addressed that with a quote passed down thru the years.
larry
