extracting a stripped recessed hex head screw?
   / extracting a stripped recessed hex head screw? #1
lively1
Madison County, Illinois - Near St. Louis
Kubota B2910
I am looking to figure out how to extract a recessed stripped hex head screw. The thing is pretty tiny, so my craftsman screw extractors won't work on them. I also thought about drilling a small tap into it and then try to screw a screw into it... Not sure how else to do it. I've lubed it up with Kroil and WD-40 and tried several larger sized hex head drivers to loosen it up, but no luck. Any recommendations?
Thanks,
lively1
   / extracting a stripped recessed hex head screw? #2
They do make stripped head allen head screw extractors. I have a set and use them from time to time.
If you don't want to buy a whole set you can also try using a Torx head bit. Get a bit that is slightly bigger than the allen head screw and drive it in with a hammer. It will cut 6 slots into it when you drive it in and usually allow you to get enough grip to remove it. Worth a try.
   / extracting a stripped recessed hex head screw? #3
that is the way I do it. Torx bit and either my hand impact driver or tap on the screw driver handle while turning. Is the screw in a blind hole? or can you screw it all the way through and get it out that way? If you do have to drill a blind hole use a left handed bit, It might catch and pull it right out.
   / extracting a stripped recessed hex head screw? #4
I have had luck driving a lrger allen head into it. You can hold an allen head at an angle to get more grip ,if it's wallowed out a little.
   / extracting a stripped recessed hex head screw? #5
Fireman Pat has got it.
A left handed drill will often screw these right out with no further work. If not, they make very small "easy-outs".
   / extracting a stripped recessed hex head screw? #6
Take a mig with .023 wire, drop a dot of weld at a time on the top and then grab that little stalagtite (mite?) with vice grips and unscrew it.
   / extracting a stripped recessed hex head screw? #7
Where exactly is this bad screw?
This may sound like a stupid question. What is a left handed drill???? Tonight I will try the torx suggestion and see what happens. I will hopefully have some success. If I could find our digital camera I would take some pics, but my wife has seemed to "misplaced" it and no one can seem to find it.
   / extracting a stripped recessed hex head screw? #9
If you have a welder, weld a piece of steel to it and back it out
Cut to size
File to fit
Paint to match !!
   / extracting a stripped recessed hex head screw? #10
A left hand drill bit has the flutes going in the opposite direction of a regular drill bit. It is used in the counter clockwise direction and thereby often times uncrews the screw while you are drilling it.
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2021 Harley-Davidson FLHP Road King Motorcycle (A59231)
2021...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
John Deere 5055E (A53317)
John Deere 5055E...
2018 Regal 29OBX 29ft Yacht with 34ft Trailer (A59231)
2018 Regal 29OBX...
