hayden
Veteran Member
- Joined
- Sep 23, 2000
- Messages
- 2,339
- Location
- VT
- Tractor
- Kubota L5740 cab + FEL, KX121, KX080, Deere 6120M
I had a Mule Pro FXT for a number of years and traded it for a Kubota X1140. The Mule pro was much faster, but also much harder to control slowly over technical terrain, which is mostly what I have. It was also very loud, as all these machines seem to be. Ear plugs are a must for anything other than a short run. And it was just a cheaply built machine with open undersides that would catch branches, collect mud, etc.
The Kubota is a substantially better built machine. Much more rugged, tractor-like components rather than go-kart-like components, much better under body protection, more metal rather than plastic, etc. The Mule always seemed like a flimsy piece of crap. The Kubota is a solid, respectable machine.
As for speed, yes, the Kubota is a dog. 25 mph on flat of down hill, but down to 15-16 on any real hill. So if you are looking for a sport vehicle, the Kubota is NOT your machine. Also if you have long flat stretches to cover adn want to move faster than 2025 mph, the Kubota is NOT for you.
But if you are looking for a rugged machine where 15-25mph is acceptable I think it's MUCH better than the other stuff out there. The accessories are much higher quality too. And for any sort of carefull picking your way through rough terrain, the HST is just fantastic giving excellent slow speed control to move, brake, and stop. This was an important criteria for my land, and the Kubota is vastly superior to the Mule Pro in this regard.
Were people fail to bond with a Kubota, it seems to be attributable to one of two things.
1) They are looking for a sport recreational side by side. That's not what the Kubota is, expect perhaps the gas powered belt driven model now available. That's a different beast much more like other side by sides.
2) They haven't gotten the hang of operating an HST. HST controls how much load the drive train places on the engine, not how much power the engine delivers to the drive train like a conventional drive. More HST peddle will make the machine go faster UNTIL you have loaded the engine to it's max power. Beyond that, more HST peddle slows you down rather than speeding you up because you are overloading the engine. You need to back off the peddle to back off the load. Anyone who has owned an HST tractor or lawn mower will have mastered this, but it takes some practice and obviously leaves many people flummoxed.
Success with an HST also requires that it be adjusted properly, and that seems to be elusive in many cases. Pressing the peddle simultaneously increased engine RPM so more power is available, and increases drive train load to move the vehicle. To work well, the engine speed increase needs to lead the HST load so there is always enough engine power to match the HST load. And you need to be certain that the engine ultimately reaches full throttle so that it develops full power. Despite dealer setup, mine was NOT set up correctly and I had to tweek it to get max performance.
Do I wish the X1140 had more power? Yes, I do. Another 10-20HP would be really nice so when I do want to make time on a smooth trail or road, I can. I do spend a fair amount of time with the peddle to the floor, waiting to get where I'm going.
