DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,591
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
Being the distributor turns clockwise, and your turning it clockwise, you're retarding it, so it shouldn't hurt anything. What the hey, turn it to where it sounds good, and see what happens.
The manuals I have skip the 200 - 230 series. I have one for the Super C, then skips to the C-123's for the 140, 240, etc. So not real sure when they changed the timing. If it runs well at TDC, go for it. If it's too far advanced, it will be firing, nearly before the intake valve closes. Could be why you're getting a little poof, when it runs.
I keep forgetting that it has been converted to 12V. Does it have a ballast resistor on it..?? It should look similar to the one in the photo I attached. It should be, depending on how they set it up, ahead of the original 6V coil, or in between a new 12V coil, and the distributor. Most newer 12V system gas tractors started on giving 12V to the points on startup bypassing the OEM ballast resistor, to give it a good hot spark to start. Then once the key, or starter button was released, current went through the ballast resistor, reducing voltage to 6V, to make the points last longer. If you can't find one on there, it'd be an idea to get one. They are about $10.00. If not, your new points will look like the one's you replaced in short time.
There shouldn't be much rotation in the rotor. Could be the pin through the drive gear is getting loose. Guess that could be determined if you have it out again, grabbing the drive gear in one hand, and the rotor button in the other, and turning one end, and see where the slop is.
I feel bad, because I may have you more confused than ever...
