Field Drag (or Drag Harrow II if you like)
   / Field Drag (or Drag Harrow II if you like) #1
DAP
From Orange County NY to Lincoln County ME
JD LX288 and a B7800
There's a Drag Harrow thread started, but I thought I put this in another categrory for the simple reason that it is a 3ph Implement that can be raised and lowered via its frame.
Its 2 8x4 field drags with 3 different settings for aggressiveness (forward, backward or upside down - from agressive to passive respectively) ...
these drag mats are hooked loosely on to a a 1/4 steel frame that fits a Cat 1 3ph.
I used it to:
1. Drag the arena
2. Prepare seed beds,
3. Bust up and drag manure pies out in the paddocks
4. Breakup up drive ice ..
5. Since I can position it just off the ground it works like a York rake if I need it to also.
The 2 chain rugs and the frame set me back about 750 new england dollars.
2016 John Deere 4044R 42HP 4WD Utility Tractor (A59228)
2016 John Deere...
2013 KENWORTH T680 TRI AXLE SLEEPER TRUCK (A59905)
2013 KENWORTH T680...
5004 (A55851)
5004 (A55851)
2012 DOOSAN G25 GENERATOR (A55745)
2012 DOOSAN G25...
2018 Toro Groundsmaster 7200 72in Zero Turn Commercial Mower (A59228)
2018 Toro...
PALLET OF 11 BARBED WIRE ROLLS (A58214)
PALLET OF 11...
