Ballast Filled tires, tubes or not?
   / Filled tires, tubes or not? #52
This is an interesting comment that I don't quite know how to respond too. I probably "really use" my tractor more than most people on this forum. While I don't plow or cultivate most of the spring and summer I steadily use most of the horse power available at the pto. While I do live in a flat area most of my work in summer involves irrigation ditches which are far steeper than most road ditches. Any sort of wheel weights would work against me and I certainly don't need it for traction. If my rear tires had fluid in them it would raise my center of gravity at the angles I work at. Besides now I can use the three point hitch to lift my rear tires off the ground. With fluid that would be more difficult.
How does your three point hitch lift your rear tires off the ground? Mine has NO down pressure.
   / Filled tires, tubes or not? #53
I wondered the same thing when he posted that
   / Filled tires, tubes or not? #54
There is no down pressure in the three point but I have a hydraulic top link and hydraulics on the mower that I use and together they can be used to lift the rear of the tractor off of the ground.
   / Filled tires, tubes or not? #55
And what purpose does that serve ?
   / Filled tires, tubes or not? #56
I mow grassed head ditched used for irrigation. Sometimes it puts both front tires on the ground so I can move. Sometimes it lets the rear of the tractor slide over so that both rear tires are on both banks of the ditch instead of one being in mid air. It lets me climb over cement checks in the ditch once the front wheels crawl up and over the cement and then when I get the back tires against the check I can lift them over too. It's difficult to explain and no doubt you have difficulties visioning what I'm doing. I should post a movie but no more ditch mowing till next spring.
2015 John Deere 550 S4 (A57149)
2015 John Deere...
2015 John Deere 245G LC Excavator (A59213)
2015 John Deere...
2018 CATERPILLAR 242D SKID STEER (A52709)
2018 CATERPILLAR...
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2015 Chevrolet Express Box Truck, VIN # 1GB3G3CG3F1110762 (A57453)
2015 Chevrolet...
2004 Fleetwood Wilderness Advantage 365 BSQS 38FT T/A 5th Wheel Travel Trailer (A56859)
2004 Fleetwood...
