Ballast Filled tires, tubes or not?
   / Filled tires, tubes or not? #41
Sorry, I meant did you jack tractor up raising tire off the ground while you Fluid Filled Tires ?
   / Filled tires, tubes or not? #43
JHurt, What kind of corrosion inhibitor are you considering, cooling system additive or something else? My dealer loaded mine with water-methanol mix, and I have wondered how bad the corrosion will be, and what form of inhibitor would mix with the methanol without unwanted reaction.
   / Filled tires, tubes or not? #44
Yes, the truck or the vehicle should be in a condition that it will handle all the loads.
   / Filled tires, tubes or not? #45
Mostly I really like having a light tractor and being able to add weight via cast iron when I need it.
That is a great method when you have soils that need a light tractor (avoid soil compaction in crop areas) at times yet uses that require a heavy rear at times (loader work). :thumbsup:
   / Filled tires, tubes or not? #47
That’s an extremely slow method.
I plumbed me up a 120v water pump that sucks out of a 55gal barrel so I know exactly how many gals I’m pumping in : 80gals in each rear & 30gals in each front. All Tubeless with 25% AntiFreeze mix.
I have an inline Tee with a cutoff to bleed air out of tire with the pump turned off
   / Filled tires, tubes or not? #48
If you have a 12V sprayer, you can rig up something similar. The 12V pump maybe a little slower than a 120V pump. Those YouTube videos called "Dave knows how" or some such has a video on exactly how to plumb up like Brown Dog did.
   / Filled tires, tubes or not? #49
Does that fitting vent the air out while filling or did you have to disconnect it and periodically bleed the air off?
You have to shut it off every so often and vent it.
   / Filled tires, tubes or not? #50
When your pumping big rear tires : slower methods will take forever.
2007 Hyster H80FT 8,000LB Forklift (A56857)
2007 Hyster H80FT...
Giyi Q.A Log Splitter (A57149)
Giyi Q.A Log...
2014 JCB 930 (A53317)
100amp Battery Charger (A57454)
100amp Battery...
HARBIN LIGHT PLANT (A58216)
HARBIN LIGHT PLANT...
Onsite begins 8:30am / Online begins 9:30am (A57149)
Onsite begins...
