Finish mower, ZTR, or both?
   / Finish mower, ZTR, or both? #1
felonius
I recently purchased 35 acres in central Virginia, of which about 20 are in the open. 15 of these acres are in old pasture that I am in the process of reclaiming. Last year, I bought a JD 5205 and a medium duty Woods 7' bush hog (thanks to help I got here!) to start mowing the old pasture, which had bunch of privet, nettles, etc. due to many years with no mowing. The pasture is now looks a lot better, but there's lots of thatch and I'd like to get a more groomed look than I'm getting with the Woods rotary cutter. I have also cleared another 5 acres at the entrance of the property, which are about to be hydroseeded. I want this part to have more of a lawn type appearance (I won't be grazing horses in this area).
My original intention was to buy a finish mower to improve the cut on the pasture area, as well as to use on the new "lawn" areas. However, some of the lawn area is fairly steep, and some has trees that have to be navigated around.
So, now I am considering purchasing a finish mower for the JD, and/or a ZTR to do the lawn areas. This could get expensive in a hurry. Should I just get a finish mower, or is it worth the extra investment in a ZTR? The cost of hydroseeding is not small, and I'm a bit worried about driving the JD over these areas with a finish mower. That and the problem of navigating steeper grades with the JD are making me consider at ZT as well. Any thoughts/advice would be appreciated.
   / Finish mower, ZTR, or both? #2
I am a big ZTR fan, but you want to have your dealer bring a mower to your property and do a demo - especially on the steep parts. A ZTR may not work for that part, but it can't be beat for covering a lot of ground.
   / Finish mower, ZTR, or both? #3
There are certain brands of ZTR's that are much better on hills than others. There are lots of knowledgable people on www.lawnsite.com. that can give you good advice. I have a ZTR and had a Woods 6 ft finish mower pulled by a JD. For hills I prefer the Woods, I never feel real comfortable doing any hill work with the ZTR. If I was to do much hill work with a ZTR I would have ROPS and a seatbelt, many come equipped that way.
   / Finish mower, ZTR, or both? #4
Even as a long time Deere man, I have to recommend one of the larger Ferris ZT mowers, with the four-wheel Independent Suspension. They have changed some models around since I sold them, but I believe that the IS5100Z, the IS4500Z and possibly the IS3100Z all have the four-wheel IS. You definitely want a model with the four-wheel IS, not the (front) two-wheel IS. I have demo'd the Ferris units on some slopes that I really should not have been on - and they were rock solid. The four-wheel IS pushes each wheel/tire down for positive traction all the way around. You definitely want your dealer to bring a few models out for you to try, but I think you would be very happy with a Ferris.
   / Finish mower, ZTR, or both? #5
A finish mower is a pretty expensive piece of equipment to use on a pasture. I would expect your rotary cutter to not be very sharp. In fact, I think you "normally" want about a one-eighth inch flat face on the edge rather than the sharper edge that finish mowers (lawnmowers) have. Now IF you are not going to be cutting brush and saplings, only grass and weeds, you can sharpen the blades on that rotary cutter and get a more finished appearance for the pasture.
   / Finish mower, ZTR, or both? #6
Felonious,
A couple of things come to mind when considering maintaining 35 acres.
1. Hills
2. Wet areas
3. Reclaimed areas
4. Terrain "Rideability"
First thing is a zero turn is gonna save you countless hours of mowing time. Second is compaction. A zero turn will weigh between 900-1200 lbs depending if you choose a 60 inch or 72 inch cut as opposed to your tractors weight and then adding the additional mower. Mowing the amount of acres you are, I would consider a 72 inch ZTR. It's wider stance and marginal weight increase are going to help you stick to the hills. Check out one of the Dixie Chopper Xtreme series 72 inch mowers. 5 acres plus per hour and a blade tip speed that you can do light brush hogging with. I think the biggest concern is the "Rideability" of your parcel. To get the true benefit of a ZTR you need to be moving quickly. Get a demo and try it on different parts of your place. It's more expensive upfront but you will be buying some of your life back buy getting the mowing done quicker.
Brian
Ace Outdoor Power
732-237-8727
   / Finish mower, ZTR, or both? #7
I have a zd28 kubota(28 hp diesel zeroturn) and I mow about 7 acres. Nothing comes close to the speed and the quality of cut of a ztr. Hands down will run circles around a tractor. With that said I an getting rid of my zd28 because you are taking your life in your hands when you try to mow steep slopes with a ztr. What happens is as you try to go down a slope as you pull the handles back to slow down the wheels lock up and it is like you are on skiis.Try go side to side and they will slide or spin out. I have used a 4wd tractor on same slope and no problem as the front wheels of the 4wd provide enough braking effect to stop sliding. I am looking at a F3680(kubota) which is kinda like a 4wd ztr. I really don't want to go with a 4wd tractor as they are slow, but if the f3680 doesn't work out I will mow the flats spots of my property with the ztr and the slopes with a small 4wd tractor.Anyway, follow the advice from the other posters and get a demo on whatever you buy.
   / Finish mower, ZTR, or both? #8
The F-series would be a good unit for you for ride and quality of cut. On several demo's the Kubota Z has done very well against other makes of Z-s on side hills.
OK, so I have zero experience with ZTR mowers and I really appreciate (but don't quite understand) what everyone is saying here. Why are ZTR's such time savers as compared to a tractor? Does it have to do with maneuverability? Speed over ground? Both? I would have thought that a 56HP JD tractor mowing open pasture would be pretty darn efficient. I may have mistated here, but my Woods rotary cutter is 84". Would a 60 or 72" ZTR be faster? If so, why? The advantage of less compaction for a ZTR is obvious though.
I needed the bush hog to reclaim the pasture area. I might have destroyed a finish mower doing that job. Now that it's under control and nothing but grass, I'd like a cleaner and lower cut. According to a previous post, maybe I should just sharpen the blades on the Woods rotary cutter, now that it's doing lighter work? Or maybe I can mow the whole parcel with a large ZTR, skip buying a finish mower for the JD, and keep the Woods rotary cutter for the few tough areas?
I may be mistaken, but finish mowers for the tractor are fairly reasonable in cost. I think the local dealer said a Woods RM 990 90" mower new was around $3000-4000 new. That's lot cheaper than even a medium duty 60" ZTR.
Thanks for all the advice. I guess the question boils down to this. I've already invested a bunch of money in the JD. Am I better off just buying a finish mower for the tractor, or should I put this towards at large ZTR instead? I already have the heavy duty Woods rotary cutter, which I will need to keep. Or maybe I just sharpen the blades on the rotary cutter for the pasture, and buy a smaller ZTR or even a decent ride-on with a belly mower for the smaller lawn areas. Am I making sense here?
Ace Power Equipment said:
Felonious,
1. Hills
2. Wet areas
3. Reclaimed areas
Brian
Ace Outdoor Power
732-237-8727
My terrain is varied. The majority is in easy sloped and flat pasture, that is now pretty clean due to two years of cutting with the heavy duty Woods rotary cutter. There are also about three acres of boggy low ground that I think would never work with a ZTR. (I probably would get stuck with the JD if it didn't have AG tires and/or 4WD in a few spots, and without the 56HP diesel the mower would stall). The newly cleared ares have some steeper slopes. I'm pretty sure a ZTR or my JD won't be a problem, it's more an issue of tearing up expensive hydroseeding with the JD's weight and AG tires. I don't know from experience, but I would also guess that a ZTR might not get enough traction to maneuver well on these steeper areas.
   / Finish mower, ZTR, or both? #11
Having used both a commercial level ZTR and a RFM on a tractor, on wide open fields or with rough or hilly land, the difference between the two is not great with regard to mowing speed. In tight circumstances or in a situation where there are lots of turns, which is where the ZTR makes up most of its time, the difference is greater. I have simply been unable to duplicate in my personal use (and I have a ZTR) the tremendous differences in mowing time that I have heard touted, and certainly not enough to merit the premium in cost of a new commercial ZTR over a high quality finish mower. If your property is not really rough or really hilly and has lots of turns, go ZTR, I think you would be happy. If it is fairly open and has some spotty terrain, the ZTR simply is not going to put that much time on a large tractor with a high quality RFM. It will put some on it, but we are speaking of minutes over your amount of property, and the cut quality would be similar.
John M
   / Finish mower, ZTR, or both? #12
An in-between solution might be one of the big garden tractors with all wheel steer. JD makes a few models and I think a few other mfrs do too. Though, this will not be an inexpensive solution. The Deere's sit very wide with a low center of gravity, hug steep hills very nicely. The AWS gives them excellent maneuverabililty, not quite ZTR like, but very good.
I use a JD425 AWS (which can be found used for about $3000) on some pretty steep slopes. Not once in 13 seasons has a single wheel ever lifted of the ground. If it looses traction, it just slides slowly down the hill. Turning in the middle of a slope has never been a problem either. I've never felt like it wasn't safe. When sitting sideways on a steep slope the hardest part is staying in the seat. Even with my body leaning downhill the tractor stays rock solid . With a 54" deck, I cut 2 acres in about 1.5 hours. I have done it as fast as in one hour, but I was really speeding about. This includes "trimming" around more than 60 trees and shrubs.
Another option would be one of the articulated machines, like a powertrac or the like.
Not withstanding the weight of your tractor, just sharpening your bush hog blades is a good suggestiong. That would save you a bunch of cash.
   / Finish mower, ZTR, or both? #13
A ZTR type mowers only advantage for time would be if there was a large amount of manuvering needed to get around objects. On rough ground the larger wheels of a tractor would fall into less diviots in the field and actually give a smoother ride for the operator. The longer runs of an open rough field would prove to be most benifical to the tractor and mower for a shorter time and comfort of the operator. We don't want to spill our liquid refreshments!
   / Finish mower, ZTR, or both? #14
Felonious,
Next questions, how often are you going to mow everything ? If your terrain is rough, I would agree a "Tractor" is going to be more comfortable than most ZTRs. However mowing with ag tires on a hydroseeded area is just like pouring beer down the drain, a bad idea. Ruts divots and resseeding are in your future. If you plan on mowing everything every week I'd lean ZTR if you can produce the 8-9-10 mph these machines can cut at. If not maybe a set of turf tires and that Woods RM may not be a bad idea.
Hope this helps
Brian
Felonious,
Hope this helps
Brian
I've been mowing the pasture about once a month. It's a good 5-6 hours of work on the JD with the Woods cutter. I haven't mowed more often than this, because grass height isn't an issue with the JD and Woods combo. If I had a finish mower, I'd mow it more often. However, I don't actually live at the property right now (and won't for a few years), so mowing myself every week is not going to happen in the immediate future. I was planning on getting back to mow maybe twice a month. I guess this is also something to consider carefully. If I went the ZTR route, I'd need one powerful enough to allow me to mow taller grass once or twice a month. Never having used one, I'm not sure what kind of speeds I could get on this sort of mowing cycle.
Your point about the AG tires is well taken. Thanks. The cost of prep and hydroseeding is not cheap. No matter how much I want to delude myself and save money on equipment, you have brought me back to the reality that a heavy JD tractor with AG tires driving through that area is a very bad idea. What I'm also realizing is that ZTR's are darn expensive too. I think maybe my first step should be to buy a finish mower for the JD to use on the pasture, and either buy a cheap used ride-on mower for the hydroseeded areas or pay someone to mow them with a ZTR this season until they are established. Then maybe next year I can make the switch to a ZTR myself or use the JD once those areas are well established.
BTW, putting turf tires on my JD right now really isn't an option, because I need the extra traction of the AG tires for other work I have to do on the property.
Having had no experience with ZTR's, I should probably demo a few and/or watch someone use one on my property before I make that kind of investment.
Is it a common practice for dealers to bring a ZTR out for a demo on your property as part of the sales process?
   / Finish mower, ZTR, or both? #16
John M
This is the very reason why I have not purchased a ZTR. My property has approximately 1.5 acres that are open and failry smooth but the remaining 3.5 acres are rough and hilly. In my estimation the speed of the ZTR would be negated by the undulations of my property. Plus the cost of a good ZTR is very high when compared to a rear finish mower.
(1) 300 GALLON & (1) 330 GALLON POLY TOTES W/CAGES (A60432)
(1) 300 GALLON &...
2018 INTERNATIONAL 4300 NON CDL 26FT BOX TRUCK (A59904)
2018 INTERNATIONAL...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
PALLET OF (3) INDOOR CABINETS (A60432)
PALLET OF (3)...
2019 MERTZ MANUFACTURING MANIFOLD TRAILER (A58216)
2019 MERTZ...
SKID STEER MOUNTING PLATE (A60430)
SKID STEER...
