First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres
This is the accordion type system that goes against the flange after seating the flange on the pvc. It is held against the flange with air pressure.
The well drilling truck - the tan one - cost around $500,000.00 not counting all the bits. This is the main control panel.
This is a picture of the Grouting Machine they use to grout the PVC casing of the well.
The area around the PVC Casing pipe is prepared by daming it so the over flow of Grouting doesn't run off.
This is the bag of Grouting material used to grout the PVC Casing to meet SC codes.
Bottom Half of the bag. You should be able to read all of the print on bag.
Pumping in the grouting material after it was prepared and mixed in the grouting machine.
Another view of the Grouting Machine. It was operated by a 13 hp engine.
A Close Up of Grouting Material after it has been mixed.
The Grouting will expand as it dries and secure the PVC Casing in the ground for the 75 feet where the PVC Casing meets the rock. This also seals the well from any contamination from the ground water. This is a picture of the top where it came out above ground level before it was smoothed and covered with dirt.
2018 Ram ProMaster 2500 Passenger Van (A56858)
2018 Ram ProMaster...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2018 Ford F-150...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
MAYTAG ATLANTIS WASHER & DRYER (A54757)
MAYTAG ATLANTIS...
Mini Skid-Steer Hydraulic Root Rake Grapple (New/Unused) (A59225)
Mini Skid-Steer...
NEW HOLLAND T4.75 TRACTOR (A52707)
NEW HOLLAND T4.75...
