First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres
This is the accordion type system that goes against the flange after seating the flange on the pvc. It is held against the flange with air pressure.
The well drilling truck - the tan one - cost around $500,000.00 not counting all the bits. This is the main control panel.
This is a picture of the Grouting Machine they use to grout the PVC casing of the well.
The area around the PVC Casing pipe is prepared by daming it so the over flow of Grouting doesn't run off.
This is the bag of Grouting material used to grout the PVC Casing to meet SC codes.
Bottom Half of the bag. You should be able to read all of the print on bag.
Pumping in the grouting material after it was prepared and mixed in the grouting machine.
Another view of the Grouting Machine. It was operated by a 13 hp engine.
A Close Up of Grouting Material after it has been mixed.
The Grouting will expand as it dries and secure the PVC Casing in the ground for the 75 feet where the PVC Casing meets the rock. This also seals the well from any contamination from the ground water. This is a picture of the top where it came out above ground level before it was smoothed and covered with dirt.
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2015 Volvo VNL 64T (A55302)
2015 Volvo VNL 64T...
2007 Ingersoll Rand P185WJD Towable Diesel Air Compressor (A52377)
2007 Ingersoll...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A54865)
2009 Chevrolet...
Hose Reel (A55758)
Hose Reel (A55758)
