First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres
This view from top of my home.
Top right looking down from the roof of my home.
View of the better part from top right of my home roof.
Side view of my tractor with FEL and Springtooth Plow.
A closer view of this plow... it needs new blades that bolts on the plows if you all know where I can get some or possibly have some to get rid of soon.
A picture of one of the Big Beef Tomato plant I planted.
Picture of onions (Red Onions) planted this past winter when I started this project with Greens.
Finally... got some time to come in here and ask some questions. /forums/images/graemlins/wink.gif
Questions:
a) My question is do the rock rakes that are made for a tractor work well?
b) Would a rock rake help me get the majority of the fist size rocks and larger from mt garden?
c) Should I remove as many rocks as I can from the garden?
d) Will the removal of rocks cause the soil to compact more?
e) Does anyone here have a rock rake they would like to sell to me to use on my Food Project?
f) Is there another tool I should be looking for to do this?
g) Would any of you that have seen my garden spot recommend using a tiller with my sloping property?
h) Have any of you visited my website lately? I have a special running for April & May.
Thanks,
Jim
Hi again!
Another question.
Does anyone have plans for a small 25 feet tall or so Lighthouse?
I want to build a Lighthouse with a storage shed over my well since it can be viewed from the roadside. It will be my testimony of what God can & will do with a little faith.
My theme and Logo will be:
"Faith is My Beacon of Hope"
Jim
Something similiar to the picture below.
Here is a place to see these:
Lighthouse Plans and different styles.
This is another Lighthouse I like... not sure I could build it or even make it work for what it needs to be able to do as far as maintenance. I would like to use some of the rocks from the garden to make it like a landmark.
Also I have to make the storage shed over the well with a roof that can be removed in case of maintenance or replacing pipe and pump. Maybe with a section of roof that is removable. Design/Plans to be modified for this purpose for sure.
I also this I may put a concrete floor around the well casing with access to waterlines and powerlines coming and leaving well. This should prevent problems with maintenance as well.
Any thoughts?
Jim
IRanch Mini 43" Bucket Grapple (A57149)
IRanch Mini 43"...
3PT DRAG HARROW (A52708)
3PT DRAG HARROW...
Vivohome Single Stage Vacuum Pump, Model VB150, 1/3 HP, 110 Volt, Vivohome Gage Set (A59076)
Vivohome Single...
40' x 20' All Metal Carport (New/Unused) (A59225)
40' x 20' All...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2007 Tri-Axle Dump Truck (A56858)
2007 Tri-Axle Dump...
