First Serious Project - Clearing 1.5 Acres
   / First Serious Project - Clearing 1.5 Acres
The other side of the Cycle Stop
Here is a Picture of the TriPod Sprinkler we have purchased to use until we get the irrigation system installed. They will also be used to spot water if and when needed.
A close up of the head. These tripods are easily adjusted.
We have a need and are looking for some 6" X 6" concrete wire to use to stake tomato plants with. We will need about 300 linear feet of this wire - 6 to 8 foot wide. This wire can and will be used over and over again for many years. It will be cut into 5 foot lengths to make a cage for 60 tomato plants. It comes in 150 linear foot rolls in our area which means 2 rolls should do. I am trying to find a concrete supply place near by to donate a couple of rolls but so far no luck. However one did offer to sell at cost which is $69.00 per roll. I can use this wire and make cages cheaper than purchasing the cages for tomato plants.
Any help would be greatly appreciated.
Thanks in advance.
Jim
Here is a picture of one of the tomato plants. It now has about 18 inches of the main stem in the ground. This is giving the plant a great root system. It shouldn't be long until they set on tomatos.
Putting pump motor on the pump
Pump, motor are over 6 feet tall. It was installed 260 feet below surface.
Water Intake before screen is applied.
2 inch schedule 80 pipe was used and antivibrators was put on for the first 60 feet to prevent pipe and pump from being damaged on startup.
This is a picture of the three wire that the four wire was replaced with when they had to repair pipe that came apart.
500BBL WHEELED FRAC TANK (A58216)
500BBL WHEELED...
Komatsu G15HT-17 Warehouse Forklift (A57148)
Komatsu G15HT-17...
2003 GMC C7500 Utility Flatbed Truck (A56858)
2003 GMC C7500...
ST205/75R15 Trailer Tires (A55788)
ST205/75R15...
Electric Utility Cart (A56857)
Electric Utility...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
