Loader Flipped my L48 Kubota
   / Flipped my L48 Kubota #121
You even did a good job showing what you did to get your tractor running, love those picture's you took. So if you would, when you break the tractor in half to change the main seal, let us know how your doing that.
   / Flipped my L48 Kubota #122
I bet it is the last time that tractor goes on its side
   / Flipped my L48 Kubota #123
Good Call.
My head gasket is leaking. :mad: I had a feeling i was gone to run into that problem. When i got the new one in, I had not gotten my old one back to get the stud out for the thermostat housing. I thought i could put it on later and mounted the head. Turns out you have to mount the thermostat housing first or remove the water pump housing, and complete timing cover housing. So I had to remove the head again. So instead of waiting 3 more days and spending another $75 on my third head gasket. I added an extra ten pounds of torque and reused the new one. I figured it never ran and got heated, and was formed to the new head that i might get lucky. Runs good but a antifreeze leak. Good news is that I have gotten so good at changing the head i can probably have it done in 2 hours. Lol. Still taking a long hard look, and trying to gather more info the main seal job.
   / Flipped my L48 Kubota #125
On the grand Lxx10 machines (and L48) Kub moved the front drive shaft inside. It's located at the bottom, well below the crank main seal. There have been posts about leaks where it comes into the clutch housing from the trans.
Unless it's leaking a flood, I'd fabricate an outside catch tray below the drain fitting to hold some high-absorbency sheets. My home-heating oil delivery guy uses them - they soak up a LOT of oil. It could run that way til you have full confidence in the engine? Just a thought. At $20/gal an SUDT leak costs too, but maybe with a little time the way forward will be more clear.
To split an L48 the outer frame has to go (see attached pdf).
TBN member messtrap took his off - (pic is a BX holding it). (orig thread here.)
  • L48 Main frame.pdf
Thank You. Drip tray sounds like a goods idea. it's annoying has **** when she leaks in a customers finished driveway. And it's not a bad leak, but she will leave 8 to 10 inch puddle after shutting down and goes through a gallon about every 75 to 100 hours. and thanks for the attachment.
   / Flipped my L48 Kubota #127
hmm.. a gallon every 75-100 hours. I might put some oil sorb sheets under her and let her go. :)
   / Flipped my L48 Kubota #128
..... Good news is that I have gotten so good at changing the head i can probably have it done in 2 hours........
Permatex makes a nifty head gasket spray. I use it on both sides.
   / Flipped my L48 Kubota #129
Did we ever find out the conditions that caused the turnover?
   / Flipped my L48 Kubota #130
here is what I read as posted by OP some time back...
Originally Posted by rmk700
My guess is with the combination of the weight of whatever is stuck in the loader bucket and it raised up, along with no backhoe attachment on for ballast, the right rear tire may have crawled up on something and without rapidly slamming the loader bucket down it went over.
Originally Posted by DrivewayMan
That, and going up that little five foot hill on a angle.
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
UNUSED FUTURE 32"...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
