Tires fluid in tires
   / fluid in tires #1
jb112454
Prague OK
2001 Kioti DK35
i just had fluid put in the rears of my dk35 what a difference it makes when using the fel. i had it done at the dealer i bought it at and he only charged me for the antifreeze put 3 gallons per tire.
   / fluid in tires #2
What size tires do you have? Or is '3 gal/tire' a typo and you meant 30?
   / fluid in tires
the 3 gallons of anitfreeze is in addition to topping off with water. the antifreeze is just to keep it from freezing in the winter. the tires are 12.4 x 24 and i think they hold about 30 gallons each which means i put about 480 lbs on the rear of my tractor. sorry for the confusion
   / fluid in tires #4
Gotcha. I see you are an OK and winter doesn't mean temps that can get to -30 F. I assume the 3 gal of antifreeze will (hopefully) keep the rust down, which shouldn't be a major problem as long as the tires are filled to above the rim at the top.
   / fluid in tires #5
John,
With only 3 gallons of anti-freeze to 27 gallons of water... what does that get you down to "freezing point" temp?
It doesn't seem to be enough anti-freeze for the volume of water used... or is my math off somewhere...? /w3tcompact/icons/crazy.gif
   / fluid in tires #6
Three gallons sounds a little light to me too, John. In my old Ford Jubilee with 12.4 x 28 ags, I think it was four gallons to get me down below 20º. I didn't test it, but that's what I was told by a tire dealer in north TX.
   / fluid in tires #7
John, he just lives in the middle of Oklahoma. It ain't gonna get quite as cold, or last as long, as in your part of the country. And maybe he's like me. I just put 2 gallons of antifreeze in each rear tire 'cause the tractor is stored inside and if the temperature is below freezing it's extremely unlikely that I'll start or move it./w3tcompact/icons/laugh.gif
   / fluid in tires #8
<pre>Updated: 04:53 PM CST on December 29, 2001
Observed at Muskogee, Oklahoma
Temperature 30° F
Windchill 22° F
Humidity 47%
Dewpoint 12° F
Wind North at 9 mph
Pressure 30.31 in
Conditions Clear
Visibility 10 miles
Clouds Clear < 12000 ft (CLR)
Sunrise 7:33 AM (CST)
Sunset 5:17 PM (CST)
Moon Rise 4:43 PM (CST)
Moon Set 6:46 AM (CST)
Moon Phase
Today Dec. 30 Jan. 06 Jan. 13
</pre>
I don't know Bird... it seems below freezing to me right now...? /w3tcompact/icons/wink.gif
   / fluid in tires #9
Tulsa, OK forecast...
Forecast as of 4:00 PM CST on December 29, 2001
Tonight
Partly cloudy. Lows in the upper teens. Light north winds.
Sunday
Mostly cloudy. A chance of light snow in the afternoon. Highs in the lower 30s. Light northeast winds. Chance of snow 30 percent.
Sunday Night
Mostly cloudy with a chance of light snow. Lows near 20. Light northeast winds. Chance of snow 30 percent.
Monday
Mostly cloudy with a slight chance of light snow. Highs in the lower 30s. Chance of snow 20 percent.
Monday Night
Partly cloudy with a slight chance of flurries. Lows in the upper teens. Chance of snow 20 percent.
New Years Day
A slight chance of flurries...otherwise partly cloudy. Highs in the lower 30s.
Tuesday Night
Maybe he has that Super concentrated Space-age Anti-freeze... One gallon per 1000 gallons of water that won't freeze until -89 degrees...[image]/w3tcompact/icons/grin.gif[/image]
   / fluid in tires #10
I understand, John. In fact our forecast calls for a low of 25 tonight (and it's usually colder out here in the country than in town), and I've seen it as low as 10 here once in the past 7 years; however, my tractor is indoors, even if the water in the tires froze a little slush wouldn't hurt anything and solid ice probably wouldn't hurt anything if you didn't move the tractor while it was frozen, and I have no intentions of using my tractor when the temperature is below freezing, so I'm convinced I have nothing to worry about and thought he might be the same. Now if I planned to use my tractor in sub-freezing weather, that would be a whole 'nuther ball game./w3tcompact/icons/laugh.gif
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
Mini John Deere Truck (A55853)
Mini John Deere...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2016 Toro Sand Pro 5040 Bunker Rake (A59228)
2016 Toro Sand Pro...
MARATHON 76KW GENERATOR (A58214)
MARATHON 76KW...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
