FMC brand brush hog
/ FMC brand brush hog #1
Anonymous Poster
Epic Contributor
I aqquired an old FMC brand brush hog (light duty 42" I believe) that needs its blades replaced (nothing hardly left of them!). Does anyone know who bought out FMC or who migh have parts. Also any advice on getting the huge bolts loose?
/ FMC brand brush hog #2
The company's name is Sidewinder,which I believe is in Georgia.I used to have the heavy duty tire drive model,FMC Sidewinder.
You may check to see if they're "left-handed" threads?
/ FMC brand brush hog #4
<font color=blue>Also any advice on getting the huge bolts loose?
</font color=blue>
HEAT HEAT HEAT.....
A torch to heat the bolt, then let it cool and it should come loose. Heating the bolt expands it and breaks loose some of the crud holding it, but the bolt will be weaker when it's hot so let it cool before you try and loosen it.
or you can aslo try....
take a hammer and give the bolt head a couple sharp, solid raps. Be sure to hit the head squarely so you don't swell it where the wrench or socket won't fit.
/ FMC brand brush hog #5
Try some "PBlaster" I have had good luck with this on all my old cars.
/ FMC brand brush hog #6
I looked around and found some literature.The model of your
brush cutter is a GM-42.The company's name is Side-Winder,
LDI Inc. P.O. Box 818 Minden,Louisiana 71058 Toll free number
1-800-654-4279 or(318)377-0383 Fax (318)377-0660
/ FMC brand brush hog #7
Those huge bolts your talking about have a machined shoulder on them which go thru the blade and the (stump jumper) pan and tighten into the flat bar (approx. 3/4" thick by 3" wide ) This bar is threaded and the bolts go all the way through with a lock nut on the end of the bolt.BACK IT OFF FIRST...then get your bolt out!
/ FMC brand brush hog #8
Hopefully the OP is still an active member, because this thread was started 12 years ago. The last reply was over 11 years ago. Best wishes. The info might just possibly assist and help other members in regards to the inquiry though.
2025 Pabreak 80in. Bucket Skid Steer Attachment (A61567)
2025 Pabreak 80in...
21ft Gooseneck Hay/Pine Straw Trailer (A65563)
21ft Gooseneck...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
Fencing Wire (A62613)
Vandale Feed Wagon (A65640)
Vandale Feed Wagon...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
