LD1
Epic Contributor
Getting ready for a overhaul. Actually its in my 5500 backhoe. 256CI I believe.
Not ready to order parts just yet, as I need to get the crank out and ground to know what size bearings I will need. But was looking at some kits, and it seems they have std, .010, up to 0.030 for the pistons/rings. But there is also a re-sleeve kit.
Do these blocks have sleeves? or are the sleeves required if needing to go more than .030? And if the block does have sleeves, I assume you can bore it up to 0.30 before needing a new one? Is that correct?
Gonna be at least a week before I can get tore into it. Planning on doing the head/valves as well. Any other things that should be done or looked that dont come standard in a "premium" kit?
