Ford8n Antifreeze
   / Ford8n Antifreeze #11
typically you fill a ford radiator of that vintage so that the water is just standing over the coils, and do not fill to the neck. in any case.. find that leak...
   / Ford8n Antifreeze
well in that case its probly just boiling out the top cuz its way overfilled its spose to be just above the coils lol anyhow i let her leak down till it just above the coils and see if quits if it does i no i put to much in if it dont then i no i got a real leak
   / Ford8n Antifreeze #13
yep.. if it will stay above the coils and not loose water past that.. should be ok.
   / Ford8n Antifreeze
would it be chapeir to just replace the radiator or to get it rebuilt anyone no of a good place to buy one?
   / Ford8n Antifreeze #15
If it was me with a tractor that old, I would just take it to a radiator shop. There's nothing worse than an overheated tractor, when you need the work done. Sometimes I might be on my tractor a couple of miles from my truck, and walking back in the Texas heat ain't too fun.
   / Ford8n Antifreeze #16
I'm sure I'm just preaching to the choir, but remember that ethylene glycol antifreeze is attractive to pets and other wildlife, and also deadly. Don't leave it out in an open pan.:thumbsup:
   / Ford8n Antifreeze
if the radiator is to full were would it leak from the cap or does itt have a overfill line somewere?
   / Ford8n Antifreeze
never mind answermed my own question its coming out the side of the overflow haha yeas that relives a headache
   / Ford8n Antifreeze
and also while mowing with the pto on i push on the clutch put it in reverse then drive back a ways push on the clutch put it in first gear and the tractor hops forward with the clutch all the way down so i tried just letting the pto come to a compelte stop before putting it in first and it work is this how these tractors are?
   / Ford8n Antifreeze #20
sounds like you don't have an over running coupler. remember.. the mower inertia spinning the mower is keeping the trans back powered.. thus you can make the driveline live even with clutch pressed.
get an orc for mowing safety.
New 4-235/80R16 Montreal Trailer Tires (A50774)
New 4-235/80R16...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
3pt Hydraulic V Plow (A50120)
3pt Hydraulic V...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
