Ford8n Antifreeze
   / Ford8n Antifreeze #31
plenty of N's are hay rakers while other machines bale..
   / Ford8n Antifreeze
what size belt do i need from what i can find its a 46 1/8 fan belt for a 1950 ford 8n front mount distributor 6 volt generator and how do i no what size ORC to get and how do i install it on the tractor?
   / Ford8n Antifreeze #33
Belt i dont know, if yours worked and you have it all, take it to carquest or nappa and they can get you a new one. THE ORC is a standard size. I think there what like 1 7/8" ?? i really dont know but you can go to TSC and ask for an over run coupler and they will give you the right one. An 8n had a standard drive shaft for the pto.
   / Ford8n Antifreeze
and also on the fron of my 8n i have pair of street tires that are old need replaced their size is 205-75-15 what size would that be converted to in a front tractor tire? a 4x19?
   / Ford8n Antifreeze #36
TSC will have your tires also.
   / Ford8n Antifreeze #37
since a 205-75-15 is on a 15" rim.. you are gonna have a bear of a time putting a 4-19 on there since it wants a 19" rim :)
you will need 15" tires to go on your 15" rims.
fords came standard with 16" rims 9 some with 19" and some optionally with 19" ) a used tire place probably has some truck tires cheap for ya. i run cheap 16" truck tires on my loader tractors to help support weight.
on the orc... your N came from the factory with a short lil stubby 3" or so 1 1/8 6 spline pto.. the newer sae standard was 1 3/8 6 spline.. and near twice as long. they make orc's to fit either... buy the orc that fits what you have. make sure your pto seal and bearing are good first as if they are not you may nd up upgrading to a sae pto shaft anyway..
if you have a belt that fits, in hand.. take it in to match it up.. or measure it.. or run rope around the pullies.
soundguy
   / Ford8n Antifreeze
so what size tractor tire would i need for the front? that would fit that rim
   / Ford8n Antifreeze #39
um.. a 15" tire is going to be needed for a 15" rim, as I said in my last post.
probably a 5.00-15 would look ok... assuming it is not a buggered up real wide 15" rim..
   / Ford8n Antifreeze #40
John Deere 51" Sweeper (A50774)
John Deere 51"...
Loader Bucket (A50121)
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
1268 (A50490)
1268 (A50490)
Ford Tractor (A50120)
Kivel Hay Spear (A50121)
Kivel Hay Spear...
