Ford8n Antifreeze
   / Ford8n Antifreeze
i figured that but hey for 25 cents
   / Ford8n Antifreeze
so im thinking about buying a Case 1949 SC row crop model narrow front end new paint job clean runing just needs hyradlic oil change motor oil change filter new gas plugs and wireschange to new bulbs in lights it alreayd runs great and everything works they only want 1300 for it now should i buy it?
   / Ford8n Antifreeze #63
i paid 950$ for a 49 VAC NF runner that needed paint, bondo, gas tank repair, belts and hoses, leak chasing, new belt pulley and rewireing and replumbing of oil gauge.. etc..
1300$ don't sound bad...
ps.. don't let low oil pressure scare you. the owner of mine sold it 'cheap' as he knew it needed rebuilding due to low oil pressure. his low pressure number was 10 psi on a leaky gauge with gas thinned 30yr old 10w30 oil. switching to a new gauge and new oil brought it to 17 psi.. book spec is 15 psi for that machine.. new.. :)
   / Ford8n Antifreeze
so on these tractors changing oil i was told that on left side their a round peaice that i should unbolt when i change oil it has a screen that needs cleaning. is the rear end like a 8n where the hole thing takes hydralic fluid? do you no the capacities of the oil/hydrolic oil/coolent or were i can get them at?
   / Ford8n Antifreeze #65
I have a vac not an SC.. they are mildly different.
IMHO.. it should use a c159 oil filter.. that is a common case and allis oil filter.
couldn't comment on the rear oil. I know my vac uses a very heavy rear end oil. I also know there are a couple different hyd setups too.
i'll see what all models my manual covers.
   / Ford8n Antifreeze
i changed the oil it takes a 1080 napa oil filter 5 quarts oil i changed oil drained the clutch oil took out the oil screen cleaned that in air cleaner only thing left is plugs wires and radiator and hydralic sysstem from what i can tell it is all one system for the hydrolic fluids
   / Ford8n Antifreeze #67
ah.. the c134pl cartridge for a cannister type.
the c159 is the spin on number.
   / Ford8n Antifreeze
ya for fram that is the right number no one had any around here expect napa so i went with theirs
   / Ford8n Antifreeze #69
yep.. walmart and tsc are the usual fram dealers here.
   / Ford8n Antifreeze #70
yep.. tsc and wallymart are the usuale fram dealers..
2016 Sure-Trac 20 Ton Pintle Trailer, VIN # 5JW2U2522G1121114 (A51572)
2016 Sure-Trac 20...
2006 Hino 268 Truck, VIN # 5PVNJ81T962S11110 (A51572)
2006 Hino 268...
2012 TRAVIS 39FT DUMP TRAILER (A52576)
2012 TRAVIS 39FT...
RoGator RG1100C (A52748)
RoGator RG1100C...
Rogers 4th Axle (A51572)
Rogers 4th Axle...
2021 LIDDELL C-55 RGN (A52472)
2021 LIDDELL C-55...
