JWR
Elite Member
- Joined
- Apr 19, 2011
- Messages
- 4,021
- Location
- So MD / WV
- Tractor
- MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
There's a lengthy thread going on now about when to use 4wd. The answer is there is no simple answer. As operator expertise rises use of 4wd declines. You'll have to find your place.
Sometimes. There are a lot of variables in the decision as to whether to use 4wd or not. Generalities are always going to fall apart in some cases and be great rules of thumb in others. There are definitely times when experience (and expertise) call for more use of 4wd, not less. I find a significant variable is steepness of the ground you're on, moisture, and of course the load and implement. Because I operate a large % of the time on steep ground and land where the mowing operation goes over a lot of variation in both soil type and steepness I use 4wd a lot more than I would on other terrain and no doubt a lot more than people with different terrain. The use of 4wd declines as expertise rises only in some circumstances (and that may well be a statistically large set of users) but use of 4wd increases with experience and expertise in other cases.
