Front Hitch Reciever on 2720
/ Front Hitch Reciever on 2720 #1
trackid
NE.WI
jd2720
IMG_1749.jpgIMG_1747.jpg Needed a way to be able to move my trailer when I had my cutter on back so I added a receiver to the front of my 2720.
/ Front Hitch Reciever on 2720 #2
I made one out of 4 x 1/4 inch angle iron for my BIL. Just be careful about where the wink link is. My BIL bent the angle and tweaked the frame a small bit with too big of a camper trailer he was trying to park.
/ Front Hitch Reciever on 2720 #3
How large of a trailer is being moved? The thought of a front hitch receiver is perfect! I have a fairly heavy (don't know weight) three horse twin axle trailer that gets moved once in a while and grabbing my 2720 which Is parked right next to it sounds like a way better solution than getting the 1T 4 door 4x4 doully, warming it up and then trying to get it lined up.
/ Front Hitch Reciever on 2720 #4
I'm not really sure but I think it is in the 24 to 28 range. I know it won't go through a 10' tall door because of the roof air conditioner.
/ Front Hitch Reciever on 2720 #5
Holly schamolly. That is a bigun for sure. Does the tongue have a wheel on the jack so it is just a push? Or is the jack lifted and the tractor has to "carry" the weight?
/ Front Hitch Reciever on 2720 #6
Oh and did you buy the setup, or have it fabricated?
/ Front Hitch Reciever on 2720 #7
I didn't see it happen but the jack was probably up.
I made it for a smaller camper he had and it worked great for many years, untill he traded it for the big one.
/ Front Hitch Reciever on 2720 #8
Did you buy the receiver assembly or make it? It looks very hand. Thanks Bigtiller
I built this hitch. Trailer is my landscape trailer, used to haul the tractor. It weighs about 2000#. The flat stock attached to the frame is 3/8". I purchased the square blank from the local fleet farm. IMG_1754.jpg Back of receiver is attached under it to a flat piece bolted to the grill guard bolts.
/ Front Hitch Reciever on 2720 #11
I find that a receiver on my FEL works pretty good as well. No manual lifting plus a little more leverage on the turns. I also have one on my hoe linkage.... One of the handiest fittings to add to your tractor.
/ Front Hitch Reciever on 2720 #12
Pat32rf - please share pictures of your setup. Thanks
/ Front Hitch Reciever on 2720 #14
Thanks Bruce. Cool idea. And I can't use this one as I don't have a backhoe. It is amazing how we can be so creative.
/ Front Hitch Reciever on 2720 #15
Yep, a front hitch is very handy. :thumbsup:
Moved a lot of trailers in the past when I had this UTV.
Moved some big trailers with this, before I sold it. :D
Now I need to put a front hitch on the electric UTV that I have now.
2016 Textron T/A 15 Ton Flatbed Equipment Trailer (A59230)
2016 Textron T/A...
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
(10) 10'-6" PVC CONDUIT PIPES (A60432)
(10) 10'-6" PVC...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
2007 Ford F-250 4x4 Crew Cab 7ft. Flatbed Truck (A59230)
2007 Ford F-250...
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
