Fuel line size
/ Fuel line size #1
paulcho
ringtown pa.
john deere gx345 Wheel Horse 518H
What size fuel line is used on a John Deere model GX345
/ Fuel line size #2
I find 5/16 to 20 hp and ⅜ over that on my small engines from different mfgrs, 15 to 26 hp air cooled singles and V twins. The fuel filters used in such machines are usually dual tipped inlets and outlets to fit both size fuel lines.
/ Fuel line size #4
This one application where even 'bigger is better' (within reason).
e.g. for 1/4" --5/16 or even 3/8" would not hurt, space permitting.
/ Fuel line size #5
If you consider the line not being able to seal at the pump and pick up etc. being a good thing, then I say go for it. There is absolutely nothing to accomplish with a larger ID fuel line on this rather than for those that want a little sport in their life by creating a fuel delivery issue or a fire... Top fuel GX345 maybe ;)
/ Fuel line size
Thank You all, I used the 1/4 inch and that worked just fine. The reason I changed the fuel line and filter the engine was surging, I had this same problem in June 1917 problem was bolts on carburetor and intake manifold were loose, Now this time I removed the top of carburetor and blew the small inlets out with the air hose, there is a brass tube with very small pin holes in it they were blocked, My tractor is a Wheel Horse model 518-H engine Onan P218
UNUSED ZJG ZJ-12 EXCAVATOR (A60430)
UNUSED ZJG ZJ-12...
UNUSED IRANCH 38" HYD MINI 4IN1 BUCKET (A60432)
UNUSED IRANCH 38"...
UNUSED FUTURE 350 HYD BREAKER (A60432)
UNUSED FUTURE 350...
2013 Ford Escape SUV (A59231)
2013 Ford Escape...
(2) 6 LUG WHEELS/GOODRIDE ST225/75D15 TIRES (A60432)
(2) 6 LUG...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
