Fuel line size
   / Fuel line size #1
paulcho
ringtown pa.
john deere gx345 Wheel Horse 518H
What size fuel line is used on a John Deere model GX345
   / Fuel line size #2
I find 5/16 to 20 hp and ⅜ over that on my small engines from different mfgrs, 15 to 26 hp air cooled singles and V twins. The fuel filters used in such machines are usually dual tipped inlets and outlets to fit both size fuel lines.
   / Fuel line size #3
It's 1/4"
   / Fuel line size #4
This one application where even 'bigger is better' (within reason).
e.g. for 1/4" --5/16 or even 3/8" would not hurt, space permitting.
   / Fuel line size #5
If you consider the line not being able to seal at the pump and pick up etc. being a good thing, then I say go for it. There is absolutely nothing to accomplish with a larger ID fuel line on this rather than for those that want a little sport in their life by creating a fuel delivery issue or a fire... Top fuel GX345 maybe ;)
   / Fuel line size
Thank You all, I used the 1/4 inch and that worked just fine. The reason I changed the fuel line and filter the engine was surging, I had this same problem in June 1917 problem was bolts on carburetor and intake manifold were loose, Now this time I removed the top of carburetor and blew the small inlets out with the air hose, there is a brass tube with very small pin holes in it they were blocked, My tractor is a Wheel Horse model 518-H engine Onan P218
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
(APPROX. 480BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 480BF)...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
Champion Vibratory Roller (A60462)
Champion Vibratory...
2022 BOMAG BW145D-5 SMOOTH DRUM ROLLER (A60429)
2022 BOMAG...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
