Gas tank build.
   / Gas tank build. #1
Shield Arc
Super Member
Port Orchard, WA.
John Deere, 4200
Welp, one of the problems with collecting old engine drive welders. The gas tank on my 1954 Lincoln SA-200 Short hood rusted out:(. Even if you could find a replacement, who's to say it's not rusted inside too. So I took a sheet of 16-GA, and made a replacement tank. I tested the welds with soap and water. I bought a can of gas take sealer. So maybe this tank won't rust out in my life time. :laughing:
   / Gas tank build. #2
When I worked at the tool and machine shop the head welder had a nice sideline business making custom tanks... some were quite elaborate for Motorhomes, Sailboats and such... even did a couple for equipment heading for the South Pole.
I've never seen anyone that could weld like he did... most were aluminum and some were stainless with the expedition tanks made of monel... the boss would let him shear up the material at work...
I admire guys like you that have the skills to fabricate just about anything.
   / Gas tank build.
Several years ago I built a 60-gallon farm gas tank out of aluminum. I cut the pieces out with my plasma cutter. I got an education on welding aluminum after cutting with a plasma. :eek:
   / Gas tank build. #4
Nice job, SA! Is that all tigged?
I'm not ambitious enough to build a new one. I'm going to try cleaning the rust best I can and resealing. :(
Terry
   / Gas tank build.
Yes all Tig welded. My biggest problem is, I have a structural welding back ground, so I'm not to good with thin material:eek:. At one point in my life, I thought 3/8-inch thick material was sheet metal.:laughing:
   / Gas tank build. #6
Haha. Having no real welding skills and an AC buzz box on the farm for over 50 years, I tended to overbuild everything with materials too heavy to avoid burning through. :D
Terry
   / Gas tank build.
This is what I'm more comfortable building. :D
   / Gas tank build. #8
Looks nice! The TIG man at the shop uses aluminum, welds it up like a box, lets it cool for 10 minutes, and then drills the 1/8" pilot hole for the filler neck. If it whooshes when the bit breaks through he knows it is air tight.
   / Gas tank build. #10
Terry
I've resealed a lot of tanks with sloshing compound... superb results for over 20 years... the new reformulated gasoline turned the sealing compound into goo... not pretty... especially since I did 7 antique car tanks and several motorcycles and tons of small gas engines...
S/N: 5D121002416 (A55787)
S/N: 5D121002416...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2025 Wacker Neuson EZ50 Zero Tail Excavator Extremely Low Hours (A56435)
2025 Wacker Neuson...
2013 John Deere 245G LC (A55272)
2013 John Deere...
2021 Troy-Bilt TB110 21in Push Mower (A55973)
2021 Troy-Bilt...
2020 Toro Pro Sweep Vacuum (A55758)
2020 Toro Pro...
