Gas tank build.
   / Gas tank build.
Give it a go. Start a thread on your build, we can talk you through it. ;)
   / Gas tank build. #22
Thanks for the support.
I came across this welder on Saturday, and couldn't resist.
Terry
   / Gas tank build.
I know I've used Syncrowaves in the past. But I don't think Ive ever seen one that big before! :eek:
   / Gas tank build. #25
Wow! Does that require and do you have 3 phase?
This one runs on 220V. But I do have 3 phase here on the farm. Terry
   / Gas tank build. #26
Not too bad for a rookie .... glad to see you sharpening up your skills .... I really enjoyed your comment about 3/8" being sheetmetal!!!
Of all the jobs and all the places which one is the one that just sticks out in your mind?
   / Gas tank build. #27
Did you use backing gas when you tig welded the tank? What filler rod? Very eye pleasing!
How is your lathe project progressing?
   / Gas tank build.
Yeah, us hobbyist need all the practice we can get.;)
No backing gas, if it was stainless steel I would have purge the tank.
I used 1/16-inch E80S filler. I welded the outside first, of the bottom, sides, and ends. Then welded the inside. I just welded the outside of the top. I really lucked out, not one leak!
   / Gas tank build. #30
Mysfyt, at this point I don't know. I can phone Miller Support with the serial number to see if it was installed at the factory. If not I'll have to take a look inside and compare with a parts diagram to see if it was installed later.
Terry
2008 DOOSAN G25 GENERATOR (A55745)
2008 DOOSAN G25...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
2016 Audi A3 AWD Sedan (A56859)
2016 Audi A3 AWD...
12V 20GPM Gasoline Fuel Transfer Pump (New/Unused) (A59225)
12V 20GPM Gasoline...
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
