Gas vs Diesel Hp vs Torque
   / Gas vs Diesel Hp vs Torque #41
SkyPup said:
I have a high performance one cylinder water cooled two-stroke racing go-kart that puts out 40+HP @ 17,000rpm and does 115 MPH.
My question is, should I remove the three cylinder diesel engine from my Kubota L-39 and install the go-kart engine to pick up a few more horsepower and more top end speed? :eek:
YES!
The only problem I see is trying to hook up the finish mower to the go cart. It should be able to mow the lawn in under 7 seconds though!
But seriously folks..... What brand engine does that critter use? The last Honda dirt bikes I raced were well over 45 hp with a single cylinder 250cc water cooled 2-stroke. (And that was 15 years ago) If a 3 banger is so much cheaper to build compared to a 4 cylinder, they probably GIVE AWAY those cart motors, heh?
   / Gas vs Diesel Hp vs Torque #42
Shoot Fire, why even ask? Git'er done!
Since the conversion will be so successful, no need to keep that nasty old 3 cyl around gathering dust. Just box it up and send it my way for proper "recycling". {no charge}
jb
   / Gas vs Diesel Hp vs Torque #43
Absolutely! Just add a few more gears and/or larger diameter tires to convert all that twist into go. You might hit 120 at 3000 rpm!
   / Gas vs Diesel Hp vs Torque #44
Seriously?
   / Gas vs Diesel Hp vs Torque #46
Oh, wait, I thought you wanted to put the L39 engine in the kart. To go the other way, you need to add a couple more tranny's in series to gear it down low enough, kind of like the Sherman's they used to put in 8N Fords.
   / Gas vs Diesel Hp vs Torque #48
Yeah, but the two stroke needs a top end rebuild every 50 hours of operation! :(
   / Gas vs Diesel Hp vs Torque #49
I'll bet that cart motor at 17,000 rpms won't get 50 hours on a top end!
   / Gas vs Diesel Hp vs Torque #50
I'd take that bet for a donut!
jb
2013 Ford F-550 4x4 Ext. Cab Service Truck (A55788)
2013 Ford F-550...
2020 Kinze 3505 High Speed 6/11 Planter (A55302)
2020 Kinze 3505...
2005 Turtle Mountain 1 Ton Military Portable Power Unit Frame Trailer (A55758)
2005 Turtle...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2019 Bomag BMP 8500 Trench Compactor (A54865)
2019 Bomag BMP...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
