GC2410 Hood
   / GC2410 Hood
prob the differences between gc2300 and gc2400 series.
don't have a 1700 series in yard right now but think it uses setup similar to the 2400 pics I posted but don't hold me to that.
edit:
if hinge is broke for gc2400 hinge part number is 6254355M2
I went and took a peek at the hood what I see is the hinge is bolted to a plate that is welded to the hood and that plate snapped off at the welds, so I think my options would be to get someone to weld it back together or maybe drill & bolt it back on so that won't happen again, thoughts?
   / GC2410 Hood #12
was wondering about that.
if weldable I would choose that but I have not had mine off so I cannot see thickness of area.
   / GC2410 Hood
if weldable I would choose that but I have not had mine off so I cannot see thickness of area.[/QUOTE
Think I need to take a welding class ;)
   / GC2410 Hood #15
This is exactly what happened to my GC2610 about five years ago. I welded the reinforcing piece back on the hood and made sure it was well done. I then masked of and repainted in black the portion of the hood level with the grille and below it. Looks fine. P.S. I drilled several holes in the small piece and button welded them to the hood as extra reinforcement.
   / GC2410 Hood
   / GC2410 Hood
Thanks for the tip!
   / GC2410 Hood
Thanks for the tip!
   / GC2410 Hood #19
You're right -- I forgot that the 2400-series was the first real change to the GC designs. Mine's one of the last 2300-series tractors. Wish I had your gauge cluster - the one that has a single plastic cover! (Mine's a real PITA to keep clean while blowing snow, with the separate teensy gauges...)
   / GC2410 Hood
This is the first tractor I have owned, I guess I am happy to hear my cluster gauge is not an issue! That would drive me nuts especially with tiny gauges. Maybe you can create a cover to protect it, you know the saying Necessity is the mother of invention, might be some idea that is simple enough to do.
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2025 Single Cylinder 40in Grapple Rake Mini Skid Steer Attachment (A53421)
2025 Single...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A57880)
2019 KENWORTH T680...
