Gearbox leaking oil
   / Gearbox leaking oil #1
calbug
Bronze Member
Georgia
Branson 4720i
my rotary cutter gearbox is leaking oil while i'm cutting grass. its not leaving spots on the concrete where i park it so i assume its goin out in the field. seal allowing some to escape i assume? i have to add some every time i use it(85W). is this normal? should i fill with grease and if so how much? i dont see anything wrong with bottom seal. no wires or anything in there and under deck is clean.
   / Gearbox leaking oil #2
Check the vent sticking out of the gear box, if its stuck or clogged pressure would be building up inside. The seal is the easiest way out for the fluid when pressure builds up. You should remove the vent, clean it with an oil based penetrant spray (WD-40, PB Blaster, Break-Free, etc) and blow compressed air through it to make sure it opens/closes properly.
Thanks, I didn't think about the vent.
2023 CASE 580 SUPER N BACKHOE (A60429)
2023 CASE 580...
2020 INTERNATIONAL LT625 SLEEPER TRUCK (A59905)
2020 INTERNATIONAL...
2016 Volkswagen Tiguan SUV (A59231)
2016 Volkswagen...
2019 CATERPILLAR 320 GC EXCAVATOR (A60429)
2019 CATERPILLAR...
2019 Ram 1500 Crew Cab Pickup Truck (A59230)
2019 Ram 1500 Crew...
JOHN DEERE 5403 TRACTOR (A58375)
JOHN DEERE 5403...
