Geothermal heat pump install with crawlspace encapsulation
   / Geothermal heat pump install with crawlspace encapsulation #81
Does anyone have one where the coils go into the lake?
It's efficient, but I would worry about someone snagging the poly with a hook. Poly is tough, but not that tough. You would have to check and make sure it is legal for you to do it on your lake. The anti-freeze would definitely need to be proplyene glycol.
   / Geothermal heat pump install with crawlspace encapsulation #82
Or today an ethanol based antifreeze. it is non-toxic and has better thermal properties than propylene glycol.
paul
   / Geothermal heat pump install with crawlspace encapsulation #83
paul
Just have to check what laws exist. Some states have voted to be only propylene glycol and it's super $$$. I have methanol in mine :cool:
   / Geothermal heat pump install with crawlspace encapsulation #84
Coils shouldn't be in the deepest part because they will get burried in silt overtime. Also make sure that the "fluffed coils" are well made with well secured spacers. Most installers use cable ties but I already learned that it would be better to use stainless steel wire or anything more duarable than cable ties. We have geothermal 10 years and I am finding spacers floating in the pond once a while.
   / Geothermal heat pump install with crawlspace encapsulation #85
Once they are in there they really shouldn't go anywhere. The silt won't hurt it either. A guy a couple years ago was worried about the pipe in his new pond so the pipe was laid out and about a foot of fill was put on top of the pipe before the pond was full.
   / Geothermal heat pump install with crawlspace encapsulation #86
They make coils specifically for lakes. and buried in silt would be prefered.
   / Geothermal heat pump install with crawlspace encapsulation #88
I've read that algae on pond pipes is wha's to be concerned about. But, I only know wha' I read.
In a closed loop system this shouldn't be an issue.
So an update after about three weeks of running the system. Haven't got a power bill for it yet but the wife has a complaint. The system is in the crawlspace under the master bathroom, which is where the old system was. But the old system had the compressor outside the house and the new system has the compressor in the crawl space. Also as part of the crawlspace encapsulation, the insulation was removed from under the floor joists. So now the compressor noise is quite loud in the master bathroom, which also means it's audible in the master bedroom. My wife's side of the bed is closer so she's complaining that the compressor noise is waking her up.
It's ironic because I was looking forward to moving the compressor inside so that when I'm out on the deck on a summer evening it doesn't kick in and annoy me. The geo compressor is quieter than the air to air compressor but the sound is still noticeable inside.
Trying to decide if I should have insulation put back into the floor joists under the master suite for noise dampening, or move the compressor (which I suspect will be expensive and complicated). Any ideas?
   / Geothermal heat pump install with crawlspace encapsulation #91
What is the unit sitting on? Is there contact from the unit or pipes on the floor joist to make the noise resonate more? You can get a jacket to dampen the compressor noise, but I would look at the other things listed above. Did your installer listen to the unit and find it acceptable to other installations?
   / Geothermal heat pump install with crawlspace encapsulation #92
My builder did this on a previous house and on mine he built an ICF building attached to the side of our house to put the compressor in. It had to be insulated since it heated hot water.
I would start with the floor insulation. Cheap and easy. You could also box in the compressor with foam insulation.
Here are a couple of pictures of the compressor. It's on rubber feet which are on a concrete block. It's close to the bottom of the joists but not touching. How much room doe a jacket take? As you can see there isn't a whole lot of room here.
   / Geothermal heat pump install with crawlspace encapsulation #94
The jacket goes on the compressor inside the cabinet. I would have your installer listen to it and trouble shoot. Then do the jacket as a last resort.
   / Geothermal heat pump install with crawlspace encapsulation #95
Would be willing to bet a little sound proofing insulation in the bays directly above the compressor would go along ways and be pretty cheap. Still may not be a bad idea to have installer listen to it. Just to make sure everything is correct.
   / Geothermal heat pump install with crawlspace encapsulation #96
No way I'd move it, certainly not without trying some sound insulation first. You can get Roxul (sp?) rock wool insulation at Lowes, and it is intended for sound insulation. Very good sound deadener. Stuff that into the cavities above the compressor unit. Double the batts if there is enough depth. If there's room, I'd also nail up a piece of OSB or drywall to the underside of the joists between the compressor and the insulation. Cover as wide of an area around the compressor with insulation and sheathing as you can. That way you will have multiple layers to damp the sound.
We have our vertical standing ClimateMaster unit in a closet in my workshop, which is really a garage bay. On the other side of the wall is our pantry closet, and then the kitchen. I can hear the compressor running from inside the pantry through an insulated wall, but it's not bad at all (not loud enough be an issue if that was a sleeping space). So I'd conclude that two layers of drywall and insulation are enough to alleviate the noise level.
Overall, one of the things I like about the geothermal the best is how quiet and inconspicuous it is. We got a ton of noise through windows of our old house from outdoor AC units, not to mention annoyance when outside on the patio. The geo unit at our new house is almost unnoticeable, especially after I installed a soft-start kit on the compressor. We don't see the lights flicker anymore when the geo unit starts up. The only way you know it's running is to hear the hallway thermostat click or feel air blowing through vents.
   / Geothermal heat pump install with crawlspace encapsulation #97
Before you do anything, if the installer is experienced, have him listen to it and see how it compares. Mine is about 12' away from my bed and doesn't bother me at all. It could be resonating off something or even have a mechanical issue to be creating excessive noise.
   / Geothermal heat pump install with crawlspace encapsulation #98
Our ClimateMaster unit and loop pumps are under our bedroom in the crawl space and very quiet. The floor is insulated underneath, and the floor is carpeted, for comparison info.
   / Geothermal heat pump install with crawlspace encapsulation #99
I installed Waterfurnace three years ago. The unit is in the basement where the old gas unit was. Sounds like a refrigerator when it runs. Don't know it is on when the tv or radio is on. Love it.
Energy cost dropped over $100.00 per month after install.
Highly recommend ground loop for anyone looking to replace their old system. I got rid of gas completely. Total electric and received a rate reduction from electric company. Total summer cost for the house is >$70 per month. Winter >$140 per month. This includes a hot tub.
   / Geothermal heat pump install with crawlspace encapsulation #100
I set mine on some rigid foam. Also, the compressors on mine came bolted down for shipping, and the bolts have to be removed for operation, so the compressor sits on springs. Check and make sure the compressor is not bolted down. I can hardly tell mine are running based on sound. And this reminds me, I need to replace the air filters.
Cummins 6-Cylinder Turbo Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2008 Jeep Wrangler Unlimited 4X4 SUV (A59231)
2008 Jeep Wrangler...
UNUSED IRGC40 HIGH END MINI GOLF CART (A60432)
UNUSED IRGC40 HIGH...
(14) WOOD PALLETS (A60432)
(14) WOOD PALLETS...
2010 CATERPILLAR 924H WHEEL LOADER (A60429)
2010 CATERPILLAR...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
