Geothermal Heat Pump Project
/ Geothermal Heat Pump Project #61
How much electricity are you using to run this unit? Glad to hear it is performing better than last winter.:cool:
/ Geothermal Heat Pump Project #62
I just found this post. Very, Very interesting and thank you for all the details. I, too, wondered why you didn't put the manifold for all the 500' sections inside the basement. Just a different approach, I guess. I learned there is more to these systems than what I see at the Seattle home shows. Thanks again.
Putting the manifold in the basement has no real advantage. It would take more room, more or bigger holes in the wall, etc. If you have faith in the fused joints, then I see no reason to have the manifold indoors.
Many systems have slices or joints outside. All vertical loops have multiple field joints. Thermal fusion is used. Any mechanical joint is specifically warned against by all of the geo heat pump manufacturers, due to possible leakage. If you see a cross section of a fused joint, it looks like one solid piece. So with the right tool and proper training, as well as pressure testing prior to backfill, there is no worry.
paul
For the last full year I averaged $ 134/mo. This is for 2900 sq-ft, all electric, w/pool, 3 computers 24/7, 4 people, 70 deg summer and winter.
Always hard to compare, but I was paying $ 30-35 per month more before, but electric rates have gone up over the last 1 1/2 years, another person in the house and other factors. One thing for sure, despite the temp being set basically the same as before, it feels more comfortable in the winter. Warmer discharge air, shorter run time and no defrost all have improved the "feel".
paul
/ Geothermal Heat Pump Project #65
paul
Wow - I probably average $134 a month for just my electric. Add another$1,500 a year for natural gas to heat my 2400 sq ft home. We're paying around $0.14 /kWh.
Someday I'm going to build my "dream house" - you can bet that geothermal is on the list. It's amazing to me that here in New England we probably have more hybrid cars per capita than anyone (save for CA) yet our building trades seem to be behind the national average as far as energy effeciency.
I've heard that geothermal isn't popular because the real savings is in the cooling side of things plus NE's granite makes installing the loop expensive.
Actually heating has also been quite a savings compared to my older conventional heat pumps.
As far as granite, it is actually a great geothermal material from the heat flow and thermodynamic point of view. True putting the pipe in it could be a challenge, but it would work great when it was done.
paul
/ Geothermal Heat Pump Project #67
Here is the simple pressure test rig. The tire valve at the bottom connected with the hose to the compressor.
paul
Paul,
Thank you for taking the time to put this thread together, lots of good helpful information. I do have a quick question, what did you do to seal up the penetration where the pipes come thru your basement wall??
Thanks,
/ Geothermal Heat Pump Project #68
Timely to see this thread pop up now, since I'm getting a quote for a geo system at my house. Bookmarked for later reading.
Paul,
Thanks,
I core drilled the foundation, about 3/8" bigger than the pipes. I fully filled the gap with silicon rubber.
Paul
/ Geothermal Heat Pump Project #70
I sleeved pvc pipe thru the wall first, used hydraulic cement. Then ran the loop pipes inside the sleave, caulking both inside and outside. I ran all my loops inside and did my header inside, so I could control each loop individually. Also, it makes purging air easy. If you header outside, you need to use to use a large flush pump to get rid of the air, by putting the header inside, with shutoff valves, you can flush with the circulating pump.
/ Geothermal Heat Pump Project #71
Geothermal is great. We just finished building our house about two mts ago. Three level house with 6800 square feet and one 6 ton water furnace unit. We did blown foam insulation everywhere with an encapsulated crawl space. Did horizontal loop. 3200 feet of pipe 8-9 feet down, 2 foot wide trenches. I rented a 314 cat excavator and dug the trenches myself.
We also have desuperheater with 2 50 gallon storage tanks and this summer our gas water heater has not come on.
We are also heating our pool with a 4 ton water furnace unit but don't have the loop hooked up yet.
Right now there is a 30% tax credit for geo units. In other words if your unit costs $60k you get $20k tax credit, not deduction.
Big fan of geothermal. Water furnace in would rate a 7/10. My installers were not that great to work with and water furnace slow to respond to service issues.
/ Geothermal Heat Pump Project #72
I would like to add my thanks to techman for this. I had seen the thread long ago and lost it. What is the best way, short of copying everything to my computer (where I would not have any updates) to make it wasy to find the thread again? I am bound to forget or lose a note of the thread title.
/ Geothermal Heat Pump Project #73
Click on thread tools and suscribe.
/ Geothermal Heat Pump Project #74
newbury, Thanks for your quick response. I already receive notification at "My Home" when a new post is made to anything where I have posted - I was looking for an easy way to make sure I do not "lose" access to threads where nobody posts for a while. Threads on this site soon move down quite a few pages if nobody posts to them. Whilst I was specifically asking in relation to this thread, there have been a few others over the last nine years where I would have liked to be able to access the information again. I thought some others would have been in the same situation and found a quick way of being able to find the old threads they wanted to check out, say for a project where they knew everybody who could help had done so two or three years previously.
/ Geothermal Heat Pump Project #75
Just a note to say thanks for doing this write up - I have only just found it this morning. Could have done with this information months ago, but even now it clears up lots of questions I had.
/ Geothermal Heat Pump Project #76
Jim, How did you manage to find the thread? Apart from scrolling through my "subscribed threads" list I still have not found a way to, shall we say bookmark, a thread to be able to find it again. There might not be an answer, and subscribing even a bit of nonsense does add it to the list.
/ Geothermal Heat Pump Project #77
I use a gmail address in my profile and subscribe to threads. That way if I have to find an old thread I just search my gmail for TBN notifications from it, they contain links.
/ Geothermal Heat Pump Project #78
I just happened to come across the thread when I was looking for more information on Geothermal Heat Pump Systems. I have had a few problems with my old (approx. 20 years old) system and needed some input on what I should do. I had my own ideas but really needed confirmation on what should be done. Voila, I found this thread and it has lead me to other posts too.
I have to say that "techman" has been a great help to me.
For future reference I just add this link to my favourites and bookmark it - I use Internet Explorer and use Google as my search engine.
HTH.
Cheers
/ Geothermal Heat Pump Project #79
Thanks Jim. I have a fairly new computer with Portuguese language software - I am not fluent in Portuguese, nor do I know much about how to operate the things apart from typing and clicking the odd button. However, I have now managed to mark the thread so I can find it again. The TBN logo will let me see it easily in a list.
AIR DUCT FAN (A60432)
2024 CATERPILLAR 255 SKID STEER (A52707)
2024 CATERPILLAR...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
2020 DRAGON ESP...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
2014 Nissan Juke SUV (A59231)
2014 Nissan Juke...
