Backhoe Giving my hoe a facelift
/ Giving my hoe a facelift #1
moriboy
SW Oregon
Kubota M7040, L3901, KX057-4, JD 650G
Did i get your attention? Ha!
OK, i am looking for opinions. I have a BH 76 backhoe which I purchased for use on a B3200. It's a great little hoe and for digging small drainage ditches and putting in water line, I think it's the perfect size. Plus it's paid for. But I have a dilemma.
The time came and I needed a bigger tractor. The little B machine has been replaced with an M7040. So, I now have a subframe backhoe that I need to mount on the M tractor. I dont think designing and fabricating a subframe is in the cards. So I have decided to either attach a skidsteer plate to it and run it off the front of my tractor, or turn it into a 3 pt attachment.
What do you guys think?
/ Giving my hoe a facelift #2
i would sell it and get a larger hoe for the new tractor.
Yes I could sell it, but I'm set on keeping it. I have a yanmar excavator for big projects. The little BH is really handy for small projects. I just wonder what it would be like mounted on the front of my tractor?
/ Giving my hoe a facelift #4
i would mount in on the 3 pt the fel is way to weak for a hoe if u mount to fel you ll bent to arms yeah i bent mine
/ Giving my hoe a facelift #5
If you have the subframe from the last tractor, and a FEL with a frame under the new tractor it shouldn't be that hard to adapt the frame to your new tractor, and attach it to the loader frame an axle. Maybe the dealer would even take a trade in of the old frame twords a new one to fit your tractor. Do you have the proper hydraulic continues pressure on the new tractor I assume you ordered it this way. :confused:
Let me ask this a little bit different. I think my original post was confusing.
What are the pros vs. cons in adapting a small backhoe to a skidsteer plate to mount on an FEL vs. making into a 3 point mount and attach on the rear.
Fabrication wise it's about the same amount of work.
Opinions?
/ Giving my hoe a facelift #7
Not being familiar with the backhoe attachment but assuming it is a small hoe about 7 1/2' model you can do it either way. I say that since the tractor and loader are quite a bit larger than would be associated with this size hoe.
/ Giving my hoe a facelift #8
If you mount it on the loader you could use it to clean out the gutters.
Yes, it's a 7 1/2 ft. Much too small for my tractor, but very handy size none the less.
/ Giving my hoe a facelift #11
I cannot imagine having a backhoe mounted on the tractor that stops me from using the loader. You know how it goes, the two implements are used together. I know I always put my bucket to the ground and lift the tractor front with it, then set the stabilizers and dig with the hoe. No imagine not having the loader. Just seems wrong to me. If it were my problem, I would make it so I backed up to the backhoe, the three point arms lifted the backhoe, and the backhoe pinned to some flat plate brackets that were bolted to the transaxle, and the three point arms stayed on the tractor.
That is a good point that I did consider as well. Although taking off the backhoe and putting the bucket on would be very easy since it's a QA.
I think at this point, although making it skid steer compatible is an intresting idea, I am going to convert to a 3pt.
2023 CATERPILLAR 262D3 SKID STEER (A60429)
2023 CATERPILLAR...
24017 (A56859)
24017 (A56859)
2009 IC Corporation PB105 School Bus (A59230)
2009 IC...
UNUSED FUTURE P45-56" MINI HYD BREAKER HAMMER (A60432)
UNUSED FUTURE...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
JOHN DEERE 7810 TRACTOR (A60430)
JOHN DEERE 7810...
