Good morning!!!!
/ Good morning!!!! #17,981
Good Evening. 1830, light rain, 62* with 90% humidity. Forecast low for tonight is 36* with 80% chance of rain, and a high of 38* tomorrow. Monday night's forecast low is 20* and Tuesday's high is 33*. I think that will be our coldest of the year to date. But we had a very nice day today. Margie and I took a walk through the longleafs, and when we got out to the road and saw Sister burning a brushpile, we walked over to visit with her. It was a good day for burning, there being no wind to speak of.
Midas and Mocha were soaking up the warm weather too.
I hope everyone had a good weekend, and your team won.
Larro
What do you have to pay those two to pull guard duty like that? Shouldn't one be facing the other direction? :)
/ Good morning!!!! #17,982
Have 15 inches of new snow here and its 8 degrees with a wind chill of about minus 15 degrees. I have drifts here waist deep.
/ Good morning!!!! #17,983
Midas {cat} is the better watchdog of the two. He is always looking and listening. If I could just teach him to bark:D
Midas got run off the front porch by the other cats for being mean to kittens. He started going up trees in the back yard to get away from the old tomcat, and soon him and Mocha were the best of friends. Now he has his own food dish without having to worry about any other cats. {he's the fattest cat we have} He stays gone most of the day, but when he's in the back yard, the two of them are together like that.
Larro
/ Good morning!!!! #17,985
Lots of little birds are swarming the bird feeder full of sunflower seeds. The big red cardinal looks like a monster compared to the little fellers. Even a woodpecker comes to visit occasionally. The little birds can sure clean out that feeder in a hurry. Out in the woods, I see birds everywhere. It's a clear, sunny day and birds flying in the woods cause flashes of reflected light, giving away their presence.
/ Good morning!!!! #17,986
Well Larro, they seem to be best buds, just lounging around, probably would be online if you gave them a couple of Ipads...
great pic
if only critters could speak...
As they say on Babe, that'll do pig, err, Mocha.
/ Good morning!!!! #17,987
It is 12* here, and may drop another degree or two before the sun comes up. I'm off to my barn, then a friend's barn for some work today. I hate to break it to you guys, but until this weather warms up, or I am back in front of the fire in the fireplace, I now fit the description of "frigid b*tch". :eek:
I MISS SUMMER!!!!
Sit back, close your eyes, and dream it's about 101 degrees outside.
You push your Cub out of the hangar. After pulling through prop a few times and setting the chocks, you turn on the mags and walla, 1st pull.
You climb in and buckle up. It's so hot, you just leave the doors open. You don't even go to the end of the runway to do your preflight runup. Firewall it. It takes an extra hundred feet to get airborn due to the heat.
Gently you climb up to about 3000 feet, enjoying the free air conditioning. You just level off and cruise. The warm updrafts have corn shucks pirouetting around at 3000 ft. You dodge a few buzzards also taking advantage of the warm updrafts. After the day's sweat has evaporated with the nice refreshing cool off flight, you notice the sun is about an hour from sunset, you float back to ground zero. A bit of crosswind has you touch your left tire down first on the grass runway. Smooth as silk. Keep the stick back. Roll up to the hangar. Tap the left brake to spin the plane 180 degrees so that you can put her tailfirst back in her hangar.
Let her cool down a bit while you piddle with small things. Fill her up with avgas to be ready for the next flight. 5 gallon jugs are heavy. Mental note to get the diaphragm pump for a 55 gallon drum.
Now, go get some more firewood. Pour yourself another finger or two of brandy in your snifter, and get ready for the next dream....
/ Good morning!!!! #17,988
Good morning
62F .07 inches since midnight plus .87 inches yesterday.
Need to hit HD later as I'm short 2 Tees for my new plumbing.
First Happy Hour of the new year this afternoon.
Hope you are all taking care out there.
Have a great day.
David Sent from my iPad Air using TractorByNet
/ Good morning!!!! #17,989
It up to 40* here. That is 1* higher than the forecast called for. I got out early and got all the outside faucets dripping, and put out extra cat food in the sheds and pump house. We have a cat door in the pump house, and there is a small gap where the two sheds go together that the cats can get through. If they are smart they will stay out of the weather. I'm going in to work early so my boss can go home. She doesn't do well with cold.
Larro
/ Good morning!!!! #17,990
My Son just came over and insists on wrapping all my outside faucets with insulation....It is supposed to get down to 6 deg tonight and windchill below 0 ...I told him we have all freeze proof faucets outside but he wants me to play it safe...I have a great son....Do any of you know if the freeze proof outside faucets really work...????We have not had temps this low before...?
/ Good morning!!!! #17,991
Larro
I have them up here in New Hampshire and they have never frozen in over 25 years. The other night it was 12 below and the water was still able to run. Now with all that said it really depends if your facet runs into a heated area.
Mine go into the cellar and are 16” in length (I think) so the shut-off is actually in the cellar.
/ Good morning!!!! #17,992
my outside lines have those little thumb screw drains that let the water drip out between the outside and the shutoff inside. If I drain those each year, no problems.
and regular spigots/hydrants/faucets too, yes running into a heated basement. It's between the walls I'm worried about, not the outside fixture.
/ Good morning!!!! #17,993
"Do any of you know if the freeze proof outside faucets really work"
They have work great for me over the years,just don't have hose connected.
/ Good morning!!!! #17,995
do we know "why" they work?
If there's water in there it's going to freeze. Just a matter of whether it does damage or not.
/ Good morning!!!! #17,996
The shutoff rod and seal extends maybe 18" into the house and the warmth there keeps things from freezing. They work just fine and I have seen them at 25 below with no problems.
/ Good morning!!!! #17,998
Good morning! 23˚ clear skies, tomorrow will be our coldest day.
Texas Temps North to South
Jim - 10˚
FG - 12˚
Txdon - 23˚
Lou - 28˚
Ron - 43˚
It got down to 8 here, before it began getting warmer! :eek: Predicted 17 tonight, and then no more below freezing temps for at least a week. Surely things will hang on for another 18-20 hours. I have enough wood to get to then, at least.
/ Good morning!!!! #17,999
Good evening. 2355, clear, 26* with 46% humidity. Forecast low of 22* and high of 35*.
Well the Noles pulled out a hard fought win. I'm glad there were not many games like this one, or my heart couldn't take it. But now FSU are National Champions for the third time. And those flags fly forever.
Congratulation to the Auburn Tigers for a great season. They were by far the best team we played this year. Now I can count the days until speed week down in Daytona.
Larro
/ Good morning!!!! #18,000
Two outside right now going down to zero or below, coldest since we've lived here thank goodness for propane heat house a nice toasty 69 where we set it. Pretty strong wind to with gusts to 30mph. No snow in forecast for next seven days and will be in 50s by weekend
iDrive TDS-2010H...
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A60430)
2019 CUSHMAN...
18ft T/A Flatbed Trailer (A59231)
18ft T/A Flatbed...
POWERTEC INDUSTRIAL BRUSHLESS P.M.A.C SERVO MOTOR (A60432)
POWERTEC...
JOHN DEERE 7810 TRACTOR (A60430)
JOHN DEERE 7810...
UNUSED SDLANCH IRET13 ELECTRIC TRICYCLE (A60430)
UNUSED SDLANCH...
