Good morning!!!!
/ Good morning!!!! #39,001
No no offense taken, I know a lot of people here don't want to hear anything that affects there right to the pursuit of happiness - which is to eat anything they want to. I know sooner or later If they are lucky they will get a second chance at life and if they are smart won't blow it the second time. Would you like meat with no seasonings - delicious veggies are all about preparations and seasonings. My wife likes the Happy Herbivore cookbooks. Some people starting out with diet change have to take baby steps, if you have the time (I don't), first start off with breakfast. Then a few meals a week etc. etc.
As far as your mental issues caused by your childhood memories, I'll have to take the DR. Phil approach: Get over it you are a big boy now!
I Had my once a month flat this morning (rock puncture) and went to Bastrop and had to make 3 high water detours. Oh wait, it's the 31st - that makes two flats for this month.
The RV park on Hwy71 at the Colorado river is flooded and 5 of the RVs did not get out and have water up to their windshields. The office also has the river in it. It rain 14" in 6 hours near the Austin Airport. The river is still rising.
You really need to start a nutrition thread. Not trying to be sarcarstic or rude. You have such an abundance of good and helpful information, it would be nice to have a central location to find all your posts, rather than digging them out of this general thread.
Congrats on your success, and please keep the good information coming.
/ Good morning!!!!
Still raining here. Supposed to be much nicer tomorrow. Didn't get much done in the shop, the outlet thingy will have to wait!
Have a good one!
/ Good morning!!!! #39,003
The gravel cleaning continues apace ... all the small/fine gravel has been double washed (at least) ... halfway through the second wash on the large gravel for the big tank.
Got the UGF's cleaned for it too ... as well as resurrecting a seemingly dead Magnum 330 powerhead /motor (bad switch)
I have absolutely no idea where that powerhead came from ... I had (and still have) a Magnum 200 ... never had a 330 as far as I can recall. It looks pretty rough, like the filter leaked on it ... but the motor runs fine when the leads are wired direct.
Got the rocks done too.
Back to cleaning.
/ Good morning!!!! #39,004
These are handy and a lot cheaper at Home Depot
/ Good morning!!!! #39,005
Drew. Skip the fitting that Kyle posted. Those suck to be polite. If they don't have a double o-ring they'll leak as soon as installed. These are the best for quick repairs on anything under 1 1/2 inches. http://www.supplyhouse.com/Matco-No...pling-400T04?gclid=CM_ziu247sgCFdgGgQodhUMCGQ Anything over 1 1/2 inches just use a Harco 2" PVC IPS Knock-on Repair Coupling (G x G) - The Drainage Products Store If you can find a knock on for 3/4 that's the best way to go.
If the glue joints are popping then you have movement. Or they weren't primed. Sounds like you really need to get that fixed. And move the power line. Typical DIY. Half assed. Deeper and conduit. But you know that.
/ Good morning!!!! #39,006
Good morning. It is strangely quiet this morning, partially due to a thick blanket of mist, but mostly because our grandson has returned home. Dog looks quite lost without his playmate and I am back to thinking what I should do today. A dolly for the log splitter is on the list, using part of an old wooden ramp, with a bit of scrap angle iron to stop the splitter sliding off the edge. I'm not sure if I would have any implements sat on wheels if I hadn't stumbled across TBN. Now the ease with which things can now be moved around has turned me into something of a dolly evangelist.
Don, I don't mind at all if now and again you climb up on that soap box of yours and tell it like it is. Statistically, you are quite probably adding years to the lives of some lucky individuals who read what you have to say and then follow even a small part of the new txdon healthy eating lifestyle..
Working away for a few days next week, so if you don't hear from me for a while, it doesn't necessarily mean I have died from my not quite so virtuous diet.
/ Good morning!!!! #39,007
good morning all. Farmer, thanks, I actually have a few of those I stocked up on for emergencies, if I couldn't get someone else to dig the hole. Since I'm going to replace this entire water hose when the garage project is done, I expect to patch it a time or two before I get through. I don't think what they used had Orings, so who knows but the ones repaired so far, the three earlier ones, have not popped open again. I think the old glue was either defective or they didn't get the glue right. These guys used two part adhesive, purple stuff and white stuff. (actually probably primer and glue)Anyone who lays a water pipe directly to the street without a shut off valve likely did not get the glue right...:rolleyes:
a warmer 58 degrees going up to low 70's today, a real heat wave...with rain starting mid afternoon. My fireman helper bought an entire pickup load of flowers and shrubs at closeout and gave me first pick, which was nice, another six little shrubs to plant today plus I got some nice flowers that will last until the next frost I suppose.
Crepe Myrtles are turning bronze out and dropping their leaves, which reminds me to run the leaf sweeper a little today. Found out the tow behind sweeper works remarkably well on lawn, but those brushes don't cut it on my paved driveway. Maybe I should have bought the giant trav vac but for now this works ok. Default is just to blow all the pine needles and cones into the woods, but thirty years of that has dumped a lot of junk into the woods right near my driveway and my hope was to suck it up instead of blow it away. Probably going to have to do a little/lot of both. All the pine trees are just full of brown needles about to drop, the yearly "harvest" and i bet fifty pounds of junk falls off every one of those pine trees. Larro loves it, he sells the pine straw/needles; me, they're everywhere, everywhere....
Lastly I scored some contraband and decided to use it up last night before it was banned forever...
(please note I did not buy bacon, sausage, ham or anything processed in my last supermarket trip)
But with a little steak rub on them, my they were good. Everything in moderation and for sure, less red meat from now on. Much less...
The handwriting is on the wall, we need to read it.
/ Good morning!!!! #39,008
Waking up early this morning or late time change you know. Lots of people with diabetes because of weight and can control it that way. Mine is genetic have to monitor carbs and red meat is a no no. Shots help keep in check now plus plenty of walking five to 7 miles a day keep my sugar In a manageable number. The Fitbit really helps me keep track of what I'm doing.
Cool start today with showers bigger rain for tomorrow then mild with some 70s showing up for our Indian Summer. Beautiful pictures Drew sorry about water line but you will get it straight I'm sure.
Looking for 22Hornet in Ruger M77 maybe it will show up soon
Good Morning
/ Good morning!!!! #39,009
2015-11-01, 0616
40 degrees right now...high of 54 and maybe some rain today.
If the rain holds off, I'll mow the fenced in area with the walk-behind mower (since it has a grass catcher) to get rid of the leaves. The rest of the lawn...well, I'll just mulch or blow off the leaves.
Inventory yesterday went well...one of the smoother inventories I've been involved with. Started at 0700, done my part about 1500.
/ Good morning!!!! #39,010
Poured second cup of coffee. 48° with partly cloudy skies this morning. Heading to 50° with lots of sun. Met buyer at my mothers house yesterday. We are all the same page. Hope closing happens soon. Having a birthday party for Son and DIL today. Wife is cooking their favorite Italian meal. Lasagna.
Drew, 4 burgers does not look like moderation to me. :D
Good Morning All.
/ Good morning!!!! #39,011
52 going to 66, and just finished getting an unexpected hard rain. Happy November and clock change day.
Glad I got leaves mulched in the front yard with the mower yesterday...was trying to beat tonight's rain and not mow on Sunday.
Also cut probably 200 pine tree saplings and sprouts growing in a pasture. Used the blade on the string trimmer, just seems the bush hog doesn't cut all of them close enough to the ground to keep the lowest branches from growing back into a little pine shrub. I guess I could lower the bush hog, but there are some dips and rises on the hill so I fear bottoming it out. Now that the grass has browned, it was easy to find the pines, and a few oaks, cherries and gums.
/ Good morning!!!! #39,012
Good morning, 50F here, heading toward 61F.
A light rain fell last night on the Trick or Treaters but we got 21 kiddies. May not sound like much but it is a lot when you compare it to the 3 we got last year.
/ Good morning!!!! #39,013
It is 69 going to 89... IT"S NOVEMBER!!!! 89 degrees is to much
Took a look yesterday, and I have grass growing in both pastures I planted last month, now if I knew how to tell the difference between rye and Bahia would probably be good. We are leaving soon to pick up our new cow.
Buppies, I understand the carbs, but why the red meat?
/ Good morning!!!! #39,014
42F light rain falling now high low 50's... more shower this afternoon.
Glad I got all of lawn and more leaves remove yesterday...7 hours.
Took my bride out to fancy dinner for her birthday...I score lot of points for that. :)
Today take Mrs. food shopping than some puttering until darkness arrives around 5pm,might catch little of the race.
Enjoy the day all.
/ Good morning!!!! #39,015
Good morning, everyone.
59 and raining. Yes, raining. Again. Weather forecast said it would all be gone yesterday. It cleared out in the afternoon, so this is a bit of a surprise. About .2" in the guage this morning, and it's still sprinkling. The PLAN was to harrow the top pasture and put down the rye seed. Not sure if it will be firm enough to harrow. Don't want damage what I'm trying to enhance.
More rain predicted for Wednesday.
/ Good morning!!!! #39,016
There are studies that suggest it red meat can cause diabetes. With me it causes my sugar level to go up as does black coffee but not diet Mountain Dew go figure. Have had this since 2002 when cataracts showed up at an early age which led to checking my sugar levels. At that point my average level was 575 way too high
/ Good morning!!!! #39,017
I'm afraid you all will get rain about every three to five days until March
/ Good morning!!!! #39,018
Enjoy the day all.
A good way to earn brownie points. Happy belated birthday to the Mrs.
/ Good morning!!!! #39,019
An unusual pattern, but after 2011-2014, and this past summer, it's going to help the ground to "heal", so I'm not complaining. I prefer green grass to brown.
/ Good morning!!!! #39,020
Good Morning. 0845, rain, 80F with 88% humidity. Forecast high of 83F with 40% chance of rain today, and a low of 73F tonight. {lower humidity while it's raining than I get most mornings} Since I transplanted collards and broccoli yesterday, a little rain would be welcome, but it's been coming down at a good clip since I've been up. I'm donning my sandals and raincoat to see if they have drowned, then a hot shower and off to work.
You guys have a good one,
Larro
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
KBH 25 TON TENDER (A61307)
KBH 25 TON TENDER...
UNUSED FUTURE FT15 EXCAVATOR (A60430)
UNUSED FUTURE FT15...
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A61306)
2006 Heil Tanker...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
2012 ISUZU NPR CREWCAB 16FT BOX TRUCK (A59905)
2012 ISUZU NPR...
