Google sketchup - free 3D modeling tool
   / Google sketchup - free 3D modeling tool #1
hazmat
Elite Member
West Newbury, MA & Harrison, ME
Kubota L5460HSTC
Stumbled across this in my shopnotes magazine. I used it to model a crib for my neice see thread here.
Very easy to use - I was productive after a couple hours using the tool (though I do have experience with CAD). Thought y'all might want to check it out - the price is right.
You can "share" your model via google's "3-D warehouse".
Maybe Muhammad can figure out how we can share models here.
google sketchup
Great minds think alike - some are quicker than others:eek: :D
Have you kept using it?
   / Google sketchup - free 3D modeling tool #4
I have downloaded and have just started to learn how to use it. I need to move it over to my desktop to start with. I think that will be easier than on the laptop.
Vernon
   / Google sketchup - free 3D modeling tool #5
I have used it a bit. But I work on computers and try to get away from them during hobby time, so I have not spent that much time.
It is easy to get started, but I never took the time to get proficient enough for anything "fancy".
I having been apprenticing in the machine shop with my 80 yr old neighbor and value that time more than computer time.
Somehow making something out of alumnimum is more satisfying than skecthing.
goneandbrokeit said:
... Somehow making something out of alumnimum is more satisfying than skecthing.
I'll say - nice work. I'm assuming they are steam or sterling engines? What's the PTO HP:D :D ?
   / Google sketchup - free 3D modeling tool #7
Off topic, but they are gasser's. Sometimes run'em with chainsaw mix.
They are of the hit and miss type. In case you are not familiar with them, they have no throttle. If you take a look at the firt pic you can see the "balls" in the flywheel, when the centrifugal force gets too great, the govenor "locks" the push rod to keep the exhaust valve open and stops gas from being drawn in.
These are scaled down version of what you might see at an antique power show. As to PTO HP never had one on a dyno but since the bore/stroke is similiar, it is comparable to a push lawnmower running really low RPM. 1HP is probably an overestimate. They can do "work", you may notice the brass water pump in the 1st pic.
   / Google sketchup - free 3D modeling tool #8
I had downloaded Sketchup a long while ago, and my daughter (11) played with it so much the "time" ran out on it. How do you override that, or do you delete it then re-download it?
   / Google sketchup - free 3D modeling tool #9
They made it free in June of this year, so if you downloaded before then, I would just delete it and download it again. There is no time limit that I am aware of in the current version.
   / Google sketchup - free 3D modeling tool #10
Thanks, that is the answer I was looking for!
   / Google sketchup - free 3D modeling tool #11
Here is something I did in a few minutes...
For example I could be attempting to explain how one of the engines in the pictures I posted go together.
To make the block there is an Al casting on top of cut out 4x4 rectangular tube.
500 Gallon Fuel Tank with Pump (A55853)
500 Gallon Fuel...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2017 Toyota Tundra SR5 Ext. Cab Pickup Truck (A59230)
2017 Toyota Tundra...
Booster Cables (A59230)
Booster Cables...
2017 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A60429)
2017 CATERPILLAR...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
