Got Snow Plow Done For 3320 JD
   / Got Snow Plow Done For 3320 JD
thanks a bunch everybody for your support, diamondpilot you were right, Well I did it!!!
Now I just need to test it out...... Come On Snow!!!!!!!
4310 I'M going to do what you said, drive to some of the places that I will be plowing...... to check for clearances.
thanks everybody!!!!!
I Love it so far!!!!!!!
I'm going to watch out for my hoses also!!!!!
   / Got Snow Plow Done For 3320 JD #22
This is what I was talking about, this area uses up all the available slack in the chain. with the way I have it set up, so it still has as much lift as possible.
   / Got Snow Plow Done For 3320 JD #23
Brandon, I have an adjustable flow valve I will drop off at the shop. I will explain how to put it on.
Dan
   / Got Snow Plow Done For 3320 JD #24
Brandon, I just put a frame mounted Kasco plow on the front of my tractor. It has a piece of 3"C channel 1/4 thick that goes from the bottom of the front mount to the drawbar mount and bolts there.This realy stiffens the bottom of the mount. The last to pics is how they mountd the cyl. With the pin removed the blade floats and with the pin in you have down pressure. This will give you some ideas if you put a double acting cyl. on.
Bill
Thanks Dan, I will look for you to stop by the shop, By the way Everybody I got to really looking everything over on my new plow assembly noticed my cutting edge was worn down on one side, so I decided yesterday to flip it over, now I got a fresh side on my plow, and also noticed one of my cotter pins was missing, so my point is everyone remember to look your plow over before you start!!!!!!
The snow will be flying real soon............
Safe plowing to everybody, and thanks again for all your input and support!!!!!!
I'll get more pics real soon..........
2025 GPS 11.5ft Utility Trailer (A56859)
2025 GPS 11.5ft...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
2000 INTERNATIONAL 4900 CAR HAULER (A58018)
2000 INTERNATIONAL...
19015 (A55788)
19015 (A55788)
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A56857)
2025 ZWB 59in...
