Grand L vs. MX
   / Grand L vs. MX #1
kuboman
Canada
B3200, L5740,
Is there a reason to go with the MX over the Grand L or visa versa? They seem so very similar in size and HP. What would be the advantage of a MX over a L4740 or the other way around.:confused2:
   / Grand L vs. MX #2
theres 2 tractors in the MX line.an they are the MX4700 an MX5100,the 4700 has i think 48hp an the 5100 has 52hp.
   / Grand L vs. MX #3
I had the chance to pick up a MX5000 when I was shopping. I looked real hard at it because it was at the old pricing. I drove a HST tractor and decided the L4240 was the right choice. There will always be a time when you want/can use more lift, but it comes with a price...size. I did not want a huge tractor as space is limited in some areas.
The L4240 has done very well and I would recommend it. I think the MX is a more simple model when it comes to features.
Mike
   / Grand L vs. MX #4
Both are good tractors, but I like the HST+ on the Grand L as well as the amenities not available on the MX47/5100. I seriously doubt one will do any more than the other. To get a substantially heavier duty model, you will need to go to a M which you cannot get with an HST.
Print the specs off, study them and then drive both and you will know which is the one for you.
   / Grand L vs. MX #5
I think they have roughtly equal loaders but if I was going to buy the tractor for lots of heavy loader work I think I would go with the MX as (I think) it has larger front tires. When lifting real heavy loads I notice my front ag tires sqat quite a bit. That kind of limits you to buying the R4s for the GL over the R1s.
However I really like the extra features of the GL. When using the loader digging into a pile of dirt being able to downshift without letting off the pedal is a great feature that now I have it I wouldn't give it up. I have no idea how well the stall guard works since I always have it on and have never stalled, so I guess it does it's job.
I'm not sure about the 3pt and which one can lift more. I'm not sure if that really matters much though as I think any 3pt attachments will be interchangeable between the two. So if you are wanting a more basic work tractor then the MX may be the best option. If you want a full featured tractor then the GL would be a great option.
   / Grand L vs. MX
So even though as specs go the MX is only inches longer than the GL4240 does the MX give the feeling of being bigger?:confused:
The loaders I think are identical except for the loader control so I am assuming as far as the loader is concerned they should lift the same load. Will the GL need to be ballasted more?:confused2:
   / Grand L vs. MX #7
I may be missing something, but why are you comparing the 4240 to the MX5100 rather than a 5240?
   / Grand L vs. MX
Hmmm...good question.....brain fart I guess. Got my numbers wrong:D
   / Grand L vs. MX #10
I came out of the 3130 and went to the L5240 with cab, love it. MX seems more farm / utility while the Grand L had more comfort,features etc.
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
(2) UNUSED 460/85R30 TRACTOR TIRES / WHEELS (A57192)
(2) UNUSED...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A59823)
1987 CATERPILLAR...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58214)
2015 TEXAS PRIDE...
