Grapple cylinder is too strong
   / Grapple cylinder is too strong
I have to admit, the vertical support was welded to the rectangle channel was positioned wrong. I positioned it to one side making the center of the rectangle support force. I will change that.
To pick things up, most of the time you need only to lock it's position in so it can't fall out.
With this 2 1/2 cylinder I can turn most things into fresh squeezed orange juice. Most of the time I can't see the piece I am grabbing. Too much force will ruin the object I need to pick up.
I like the design, it works well. I could have used a smaller cylinder thats too late. Now I was looking for an easy way to lower pressure at the cylinder.
Can I somehow relief pressure into the other side of the cylinder?
   / Grapple cylinder is too strong #13
I was not talking about the cylinder anchor point on the rectangular piece of metal, but rather the triangular mount on the action end.
   / Grapple cylinder is too strong #14
Can't you adjust the relief right at the valve?
BTW, anyone ever tell you that you look like John Elway?
   / Grapple cylinder is too strong #15
He wants high pressure except at the grapple.
Triangle end has giving me no problems
My twisting action was here in the pic.
   / Grapple cylinder is too strong #19
How is this connected in? Does it need a return line?
Yes, you will need to run a hose either to tank, or to the FEL valve tank return line using a tee.
   / Grapple cylinder is too strong #20
You can see that it broke at the edge of the weld, which is the weakest part. I would add a 45 degree wedge on at least two sides.
Westendorf 400 bu Gravity Wagon (A59814)
Westendorf 400 bu...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
207271 (A52708)
207271 (A52708)
