Grapple For BX23
/ Grapple For BX23 #1
AKKubota
Alaska
JD 2520
I am considering purchasing a BX23. Does anyone know of a grapple kit / bucket for use on the BX? I contacted ATI and they said there GK4866 won't work bcz of the center cyclinder on the FEL. Suggestions?
/ Grapple For BX23
Perfect, thanks.
/ Grapple For BX23 #5
Jeff at American Solutions has a grapple setup for the BX22.
Because of the hydraulic changes in the BX23 the setup won't work as is. Because he doesn't have a BX23 and the nearest one is 40 miles away I have been working with him a little on getting the new setup going (I hope I have dibs on the first one /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif ).
It looks like the new setup "might" be using electrically operated valves to select between the curl cylinder and the grapple cylinder via a switch mounted on the loader control handle. This will solve some issues with not getting full pressure to the grapple cylinder as well as save hydraulic hose and control valve mounting problems.
He was supposed to get some selctor valves in monday so he is very close to getting it going. If the valve bracket he sent me is any indication the grapple will be top quality fabrication.
/ Grapple For BX23
Excellent info, thanks again. I've spoken with a couple of dealers and nobody knew anything about who to approach on this. Let me know when this is ready.
/ Grapple For BX23 #7
Keep us posted I am ready to order one for my bx 23
/ Grapple For BX23 #8
I will keep everyone "posted" /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ Grapple For BX23 #9
I spoke with Jeff today and he has the setup working on his Bx22. He is waiting on a hydrualic expert to check it over just to make sure.
Junkman has the original design on his BX22 and if you do a search on his name you should come up some threads. Junkman cannot post to the forums at this time and has asked me to relay his e-mail to any interested parties upon request. So if you want to contact Junkman just PM me or whatever.
/ Grapple For BX23 #10
Looks like it's going to be 2 or 3 weeks before the grapple ships.
I can hardly wait
/ Grapple For BX23 #11
Junkman can't post to the forums but can receive PM's ... please elaborate ...
/ Grapple For BX23 #12
Best not to go there, or you'll get banned too. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
/ Grapple For BX23 #13
Banned???? /forums/images/graemlins/confused.gif
/ Grapple For BX23 #14
I can recieve pm's and can then send his e-mail address.
I don't know why he can't post and didn't ask. He has always been nice and helpfull to me on here.
/ Grapple For BX23 #15
Got the grapple yesterday.
It will be the weekend before I can install it.
Here is a picture of it in its shipping crate.
/ Grapple For BX23 #16
Here is one of it out of the crate.
/ Grapple For BX23 #17
Here is the contents of the box that came with it.
I will probably get this thing installed by sunday.
It's taking a lot of will-power not to take a day off work to
uh "work" on this.
/ Grapple For BX23 #18
Any idea if it will work on a BX2200? Also, what was the cost on this add-on?
/ Grapple For BX23 #19
Bernie, could you explain how the grapple is plumbed for hydraulics? Not really addressed on their website.
/ Grapple For BX23 #20
Tooldad
Yes I do believe that it will fit a BX2200 as this model is mentioned in the intructions for the first generation grapple.(see below)
RichT
Originally the grapple was operated with a valve that was plumbed in with the loader valve hydraulics but because of a bunch of stuff I don't understand enough to explain properly (power beyond valves and all that) the grapple would not get full system pressure untill you used another operation with the loader valve. Eg. you would simultaneously close the grapple and lift the bucket. Wich is certainly do-able with the valve spaced closely enough together. I brought up the option of using a diverter valve on the bucket curl circuit, Jeff liked the idea and it also eliminated a lot of hydraulic hose and the problem of making a valve bracket for the BX23. Jeff has a BX22 and Kubota changed how the loader and control valve mount to the tractor between the 22 and 23., The nearest Bx 23 to him is about 40 minutes it was a real pain to try and get to the dealer and make measurements during working hours. Now the diverter valve(Actually there are two vavles) mount to the loader cross bar and a wire is run back to a switch. When the switch is depressed hydraulic pressure is diverted from the bucket cylinder to the grapple cylinder.
Right now I am working with Jeff to verify the new instructions
and am taking a lot of pictures. I plan to put it all in an install thread when I get it done, hopefully by Sunday evening. If I get it done and it's not rainging I am not going to be sitting here in front of the computer while its daylight /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Oh
I believe the price that is on the website of 1249.00 is what it's going to be. Plus shipping, its shipping weight was 140 lbs and it was about, rough estimate, 50x30 inches. I work for a LTL trucking company so I got a discount, anbd I picked it up at my terminal (you would think I could get it for free but the bean counters don't like that kind of thing /forums/images/graemlins/grin.gif)
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
Adams Tender Trailer (A61306)
Adams Tender...
1993 M149A2 400 Gallon Potable S/A Water Tank Trailer (A59228)
1993 M149A2 400...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
2014 NISSAN NV CARGO VAN (A59905)
2014 NISSAN NV...
26120 (A56859)
26120 (A56859)
