greasing TN rear hub
   / greasing TN rear hub #21
Rowski.. yes.. if the seal is outboard of the bearing, then the bearing is getting spalsh lubed, and the seal is seperating the bearing/oil from the exterior environment.. and apaprently the grease on top of that to protect the exterior face of the seal..
After seeing this extra info it does make a difference. I was thinking like DP that it was a stationary fitting at the end of the axle trumpet.
After hearing that the bearings are splash lube.. I like the design much better.
It must be #10 that is the outboard seal that the zerk # 4 is lubing the face of.. etc. Unless I'm seeing it wrong.
Soundguy
   / greasing TN rear hub #22
I am unable to find a grease fitting on the rear hub/axle on my TN75S (Supersteer, cab, '03 model I think) I note in the manual there are lots of different ways to grease these models, depending on 2wd,4wd, supersteer, etc. Am I just overlooking the fitting? The manual has terrible illustrations but I looks like it should be right in the middle of the hub facing outwards. Can anybody help?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2023 CAN-AM HD7 RTV (A59823)
2023 CAN-AM HD7...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A56438)
2012 MACK Tender...
2017 Bobcat T770 Compact Track Loader (A56438)
2017 Bobcat T770...
