Grounding Rod For Portable Generators Necessary?
   / Grounding Rod For Portable Generators Necessary? #121
Wow, relax. I was clarifying for people who didn't know the difference. I actually thought you did when I wrote that, I guess not. :) No satisfaction whatsoever and it wasn't my intention to debate, simply clarify the difference between the ground rods (which do not clear faults) and EGCs (grounds) (which do, and is their "primary" purposes)
I'm not sure what you mean "no longer in use", my other examples like metal appliance cases/frames clearly are. It's just not frequent you see a metal-cased drill or hand tool anymore. Stoves, dish washers, refrigerators, etc. all still do, metal surface-mount EMT receptacles, etc
The EGCs DO clear shorts/faults. The ground rods DO NOT. They are both connected together, as is the neutral.
Don't look for me backing your statements, you wrote it. "(no longer in use really), etc..."
   / Grounding Rod For Portable Generators Necessary? #123
I am new to this forum and would like to communicate with others who have CS Lister diesel gen. sets as well as changfa's Thanks
   / Grounding Rod For Portable Generators Necessary? #124
Lots of info in this thread - but here is a guy who likely did not read any of it :D LOL
(well, the grounding rod is in the dirt....)
   / Grounding Rod For Portable Generators Necessary? #125
Good one Dave. :laughing:
Now that's a guy that likes to be code compliant. :confused2:
   / Grounding Rod For Portable Generators Necessary? #128
Manufactures covering their behinds in these days of litigation. Is the resistance to grounding more about balking when somebody tells you to do something that you can see no advantage for yourself to do?
A two ft long ground rod will at best prevent a static charge build up.
   / Grounding Rod For Portable Generators Necessary? #129
   / Grounding Rod For Portable Generators Necessary? #131
A lot of us, including my self, tend to get too technical on these type posts from folks that are not EXPERTS like we are. Then there is the obvious bad information passed on as gospel that make the solution and understanding worse.
Sitting back and reflecting on this issue I feel sorry for the poor guy who asked the first simple question, "Does a portable generator need to be grounded to a ground rod (paraphrased). The simple answer "NO" (the code answer) has gotten lost in a lot of technical jargon he could probably care less about. His only concern was Safety. Even a generator connected to a house service would be grounded via the service ground system. If you feel better adding a ground rod and conductor at the generator, do it, you will never know the difference.
Bottom line: If you get the Soares manual, portable generator systems are discussed in detail on Page 41. If you are still confused you need to talk to a professional electrician.
Ron
   / Grounding Rod For Portable Generators Necessary? #132
Ron
I would think he's gotten his answer by now. He posted over 3 years ago. :)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2025 CFG Industrial QK18R Mini Excavator (A59228)
2025 CFG...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A56438)
2023 Unverferth...
Bigfoot Plastic Baler (A57148)
Bigfoot Plastic...
2012 CATERPILLAR 308D CR EXCAVATOR (A59823)
2012 CATERPILLAR...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56438)
2022 Brush Wolf...
